Dual Mufflers for G35 Sedan
Originally Posted by ttrank
Who is this person that has done it before? In all my time on here I have never seen this thread?
It's such old post the photos were gone.
https://g35driver.com/forums/showthr...highlight=dual
I would love to do this as well. But I have a few questions. Maybe somebody more up to speed on exhaust theory can help out.
Why do the mufflers need to be at the rear? Or at the least, why would both rear mufflers need to be in the rear?
Specifically, if one were to use a setup like stock, or the stillen/borla with a single rear section on the driver's side, could an outlet be routed to run beneath the car with a curve and tip? I know it wouldn't look symmetrical.
My point is, can this problem be solved with some imaginative piping and use of off-the-shelf components(magnaflow, for example) without having to relocate the evap cannister?
Originally Posted by Socal_G_sedan
TUNERDAD had it done, and he said it sounded like ****. ANDY CHIME IN AND SHOW THEM YOUR PIX!!!!!!
. He has since converted to the HKS
I like the look of a clean muffler back there.
It seems like the easiest way to do this would be to have a few resonators in line and a mid-muffler like the borla has, then just have straight pipe back to two tips. No bulky muffler back there.
When I do my motor build I am going to need to go up to dual 3" so I will look into something like this at that time. Maybe before if I get anxious.
Originally Posted by jimmyc13
Yeah, there's pictures somewhere on here of a member who did it (I couldn't find them just now). I'm a huge fan of dual exhaust, but the install I saw didn't look that good....the exhaust ports were too close together & not far enough apart. Maybe someone else will find it. Not worth the $ though IMO. Go w/ an aftermarket sport muffler.
1) It doesn't add anymore power
2) It's more expensive
3) It added unnecessary weight
I guess for the 2nd gen car, too many people wanted the dual tip look of the coupe along with other well-liked coupe styling cues.
we dropped my exhaust on the dyno and only gained 10 HP. as much as I like the look of the duals on each side, it is not worth it.....I already dual 2.5s (similar to a borla but with separate mufflers in the back.)
