6MT car shaking issues...
Old Mar 6, 2007 | 01:11 PM
xd7564's Avatar
I have an 04 6MT sedan, when i take off in first gear from a stop, the car shudders when the clutch engages. Any idea what this could be? I'm guessing its not normal.
Thanks
Old Mar 6, 2007 | 01:12 PM
ttrank's Avatar
Grocery getter
Sounds like you are about to stall.
1) rev it higher and let the clutch out a little faster
2) how many miles? you may need a new clutch
Old Mar 6, 2007 | 01:51 PM
xd7564's Avatar
I've tried reving higher and releasing the clutch... i still feel it but its not as bad.
Have 62K on the car
Old Mar 6, 2007 | 02:20 PM
Sir Boostalot's Avatar
Have 62K on the car
You might have a warped flywheel.
Old Mar 6, 2007 | 04:12 PM
xd7564's Avatar
That was my initial guess...Don't think a worn clutch would cause the car to shake....
Old Mar 6, 2007 | 04:17 PM
ttrank's Avatar
Grocery getter
True. The only way a warn clutch would cause a shake is if it were not wearing the same or if it was bad enough to cause the car to stall. Either way if you are at 62k it could be time for a new flywheel.
Old Mar 7, 2007 | 02:20 PM
xd7564's Avatar
anyone know of a good flywheel that's pretty driveable? I would rather get something driveable than make my car faster....
Old Mar 7, 2007 | 04:16 PM
chobble19's Avatar
go with the jim wolf clutch/flywheel combo! $750 shipped in the vendor classifieds....
Old Mar 7, 2007 | 05:48 PM
VQ Hotness's Avatar
If you recently replaced your clutch then you might not of broken it in right and glazed your flywheel. My car shutters a little bit due to me running my car hard after about 120 miles on a new clutch. This is most likely not the case with you.
NemesisGee
Aug 11, 2015 07:10 PM
ghost_g35
Aug 7, 2015 10:31 AM
multimut
Canada
Jul 26, 2015 08:43 PM
nervseele
Jul 17, 2015 11:21 PM
