Default Blink Rate and Measurement Question
Old Mar 8, 2007 | 10:38 AM
MidnightG35X's Avatar
Does anyone know the default blink rate on our cars? Also, anyone know off hand the measurements of the blinker section of the tail lights of an 04X?
I need this info for a sequential LED turn signal
Old Mar 8, 2007 | 11:07 AM
ttrank's Avatar
Grocery getter
No but you have my attention...
Old Mar 8, 2007 | 11:35 AM
I have your attention for what part? You actually care about the blink rate and the measurements, or the sequential LED part? I have a post going in the lighting section specifically about the sequential LED part.
Old Mar 8, 2007 | 11:56 AM
ttrank's Avatar
Grocery getter
The led part. I need to go take a look at that thread.
Old May 14, 2007 | 01:00 AM
OK, after many months, I finally am working on the sequential LED board again, so I had to get these measurements myself. So in case anyone ever needs them, here they are. I also got some current and voltage measurements for stock. These numbers are taken when the car was not running. For all who don't care about the pictures and just want the original post answer: 350 ms for each "on" pulse.
Sequential LED Turn Signals
Stock Rear Turn Signal Current:
Interesting to note is the initial spike in current right as the bulb turns on. Most likely due to changing resistance as the filament heats up. Also shows the inefficiency of regular bulbs
Stock Rear Turn Signal Voltage
Stock LED Rear Parking Light Current (No brake)
My LED Sidemarker Blinker Current
My LED Sidemarkers
Stock Sidemarker Parking Light Current
As you can see from the last 2, my sidemarkers not only look better, but even with blinkers, I still draw 40 mA less current than stock
Old May 14, 2007 | 06:33 AM
BuckeyeG's Avatar
Sounds like a good mod if you can make this I think it will be something popular.
Old May 14, 2007 | 12:51 PM
ttrank's Avatar
Grocery getter
Can't wait to see how they come out.
Good luck!!
mtlruss
Dec 20, 2015 01:51 PM
Detailed Image
Aug 17, 2015 02:45 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Detailed Image
Jul 29, 2015 08:42 AM
kenthung
Jul 21, 2015 05:56 AM
