Sequential LED Rear Turn Signal
Old Mar 7, 2007 | 02:52 PM
MidnightG35X's Avatar
Sedan Sequential LED Rear Turn Signal
Has anyone tried to make a sequential LED rear turn signal? There were some done over at my350z on a Z.
http://www.my350z.com/forum/showthre...light=LED+tail
I've never taken out the rear light assembly, so I'm not sure of the size and all that. It would be a project I'd be willing to undertake though. I think it could look pretty sick on a G.
Old Mar 7, 2007 | 03:41 PM
dream_G35's Avatar
our turn signal would be a sequential ring then?
Old Mar 7, 2007 | 04:17 PM
Hi-TechG35's Avatar
I think it would like kind of hot too. The rear tailight is not that hard to take apart. The only thing that looks tough is that most of the light is a circuit board of LEDS!
Old Mar 7, 2007 | 05:57 PM
I probably should have mentioned I have an 04, so I don't have rings. The circuit board doesn't scare me, its the disassembly and reassembly of the tail light that I'm always worried about. A couple things I'd have to figure out is the spacing inside the housing, along with what is the default blink rate on our cars (blinks per second). I've already got an idea on what I'd use for parts, based off of the link above and my own experience with my LED clear corners. It also helps when electronics is your job
Old Mar 7, 2007 | 08:13 PM
IvoryGT's Avatar
I think it would be hot to have the rear turn signal to be LED ring and sequential. Alot of work needs to go into this....ah..more potential project.
Old Mar 7, 2007 | 08:28 PM
I guess having a sequential ring is a hotter topic than the 03-04 sedan lights What would you want to do for the ring? Just spin in a circle when you have the signal on? Or start on the middle inside, and then have it work around the ring to the outside?
Either way, does anyone have some of the measurements of the 03-04 sedan lights and the blink rate? I think this project will happen this spring for me... possibly even before I do the LED interior conversion...
Old Mar 7, 2007 | 08:37 PM
IvoryGT's Avatar
I have a coupe.. But I imagine a circular motion will be more noticeable but a sequential to the outside is cool too. For the coupe, I will have to first do the GTR style dual rings and Im thinking about for turnsignal it will go from inside to outside creating a rear filled circle inside the larger ring.
Old Mar 7, 2007 | 08:50 PM
izmir41500's Avatar
G35driver Addict
GTR style dual rings ftw!
back on topic. the sequential turn signal is an awesome idea. go for it!
Old Mar 7, 2007 | 09:16 PM
papiloco21's Avatar
on a coupe...we should have current turn signal rings become LED rings....so now we have the GTR look with 2 LED rings and have the inner 3 rows of stacked LEDs become the signals.
Old Mar 7, 2007 | 10:04 PM
IvoryGT's Avatar
I dont know if the inner stacked being signals are good..they are too close to the middle. It'd look weird. Im going to mess with the stock location
Old Mar 7, 2007 | 10:58 PM
papiloco21's Avatar
yea perhaps.....
Old Mar 8, 2007 | 10:25 AM
So the general consensus is that yes, I should go do this
Old Mar 8, 2007 | 10:27 AM
izmir41500's Avatar
G35driver Addict
^ on the double.
Old Mar 8, 2007 | 10:30 AM
dream_G35's Avatar
yes do this! i even dreamed about it last night , weird. haha.
it would look good, according to my dream
Old Mar 8, 2007 | 10:35 AM
Haha, I guess I'll have to get on it then. Breadboarding it shouldn't really be that bad. Sorry to disappoint you guys though, when I finally post pics (however far into the future that is), it won't be the rings y'all are all seeming like you want Us sedan folks need some uniqueness too....
