Need feedback on spacers for M45 wheels
Old Mar 13, 2007 | 03:12 PM
genge24's Avatar
Question Need feedback on spacers for M45 wheels
What mm spacers do I need for the 19" M45 sport rims. I've searched numerous threads, but I keep running into different numbers? Do I need 5mm or 10mm? Thanks guys!
Old Mar 13, 2007 | 06:37 PM
G35Papa's Avatar
I've seen others put 10mm spacers when doing the M rims.
Oh and you didn't search hard enough
4 threads down when I did a search for M35 rims
https://g35driver.com/forums/showthr...light=m35+rims
Old Mar 13, 2007 | 07:01 PM
bert039's Avatar
Just to use the rims and not rub anything, you would need a bare minimum of 5mm in the front. The rears are fine without a spacer.
For visual appeal, its just up to you and your personal preference. You can go with anything between 5mm to 15mm front and back and still not rub. I had a set of 15mm all around and I thought it looked great. It was nice, aggressive, and the tires stayed within the fender line. The car is slightly lowered and ran 245/40/19. My fenders are not rolled.
In regards to performance, I've only tried stock vs. 15mm so I can't say whether a 5mm or a 10mm would be better. In comparison to stock though, the 15mm spacers did give the car a more sure-footed feel.
As a general recommendation, I might recommend going with 10mm all around. Be sure you get a set with extended studs and hubcentric rings too.
Old Mar 13, 2007 | 08:14 PM
LuXXXz's Avatar
the rears i belive require 15mm spacers
Old Mar 13, 2007 | 08:27 PM
godmans's Avatar
I don't think the rear requires anything... if anything, most people have just put on 5mm spacers front and rear
Old Mar 14, 2007 | 02:47 AM
genge24's Avatar
Is it fairly easy to install spacers? I have had no exposure or experience with em. I don't know what to expect i guess.
Old Mar 14, 2007 | 12:25 PM
jimmyc13's Avatar
Expect to have to install longer studs as well. With 5mm spacers the lug will barely thread on there, and with 10's, I doubt it'll fit at all.
Old Mar 14, 2007 | 01:40 PM
FenixL1P's Avatar
i didn't need spacers in the rear but i put them on just to even out the track all around.
Old Mar 14, 2007 | 01:47 PM
LuXXXz's Avatar
how does it sit w/ the fender??
jsimonk
Dec 22, 2023 03:49 PM
obender66
18 Inch
Mar 13, 2016 12:20 PM
tphan
Aug 31, 2015 10:45 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
