VDC , SLIP , BRAKE light on - brake fuse blows
Old Mar 22, 2007 | 06:34 PM
ttrank's Avatar
Grocery getter
There is a short to ground somewhere.
Do you have a wing? Check the wire on there, mine shorted out and caused the same problem. I put a fuse on it until I take it off to find the location. That way if it blows I only loose my wing light and not all the brake lights.
Old Mar 23, 2007 | 11:36 AM
ttrank's Avatar
Grocery getter
It could have pushed the wire against something that would strip it over time.
Old Mar 23, 2007 | 11:57 AM
05BLACK6MT's Avatar
brake
run a hot wire from your third brake light to the back brake lights, run another ground up to your brake from the trunk. for the rev. light jump it from the good one to the burn out one. Same **** happened to me but dealer wont do **** about it. Let me know if you still have trouble.
Old Sep 7, 2010 | 12:10 PM
lilcobrar's Avatar
Hey I just had the same issue. All three lights came on. It had a blown stop lamp fuse. I replaced the fuse and it popped it again right when i hit the brake pedal. So after reading some on here I went right to the brake light in the wing. I unplugged it and replaced the fuse. Good news that was the problem. I then used a power probe to test all the wires. It was broke in the long rubber grommet that goes from the body to the trunk. It's working perfect now. Thanks
Old Sep 8, 2010 | 08:15 PM
GOAT35's Avatar
VDC issue might just be a sensor behind the engine.....have you washed ur car lately...thats what happened to me.
Old Sep 22, 2012 | 01:04 PM
Preyn's Avatar
Hi guys! I got a same problem. tell me pls where I can find a fuse for the brake light in 2005?
Old Sep 22, 2012 | 11:40 PM
Adro's Avatar
At least he searched! Try to look up a wiring diagram
Old Mar 28, 2014 | 07:29 PM
pxzusa's Avatar
You mean the rubber flexible tube near the trunk lid hinge to the trunk lid? Thanks.
Old Mar 28, 2014 | 07:33 PM
pxzusa's Avatar
On my 06` G35 6MT, it's left side of break paddle.
