VDC , SLIP , BRAKE light on - brake fuse blows
Old Feb 6, 2015 | 01:14 PM
demetriG35X's Avatar
Originally Posted by pxzusa
On my 06` G35 6MT, it's left side of break paddle.
I had to disconnect my spoiler third brake light,( not oem spoiler) it was blowing out the brake switch fuse, thanks for this post , i also replaced the switch just in case. Now to find out why its blowing it out.
Old Mar 9, 2015 | 01:32 PM
madsen534's Avatar
I am having the same problem. I unhooked my 3rd brake light and changed my brake light switch and fuse. It worked for a min then I checked later on and blew the fuse right away.
Old Mar 9, 2015 | 07:13 PM
So you are having a short somewhere,, mine was shorting out because i had an aftermarket spoiler ,,the spoiler brake light was connected to the oem 3rd brake light...i disconnected the spoiler one and everything works now.
Old Mar 9, 2015 | 09:33 PM
madsen534's Avatar
Yeah I just tore all of the carpet out and didn't find anything but I made my harness hang down so I can stop blowing fuses til I find out what the problem is on Sunday
Old Jul 22, 2015 | 10:08 AM
GringitoLoco's Avatar
I'm currently having the same issues as the OP; VDC, Slip, Brake light comes on at first touch of the brake pedal. Last night I had a friend plug in his OBDII scanner to see if it was throwing any codes. Sure enough, the code received was P1805 - "Brake pedal position (BPP) switch - circuit malfunction"
http://www.dtcsearch.com/P1805/Infiniti/
Has anyone else seen this?
Two weeks ago I cut open the rubber hose between the body and the trunk and re-spliced (soldered and insulated) three wires (2 grounds and a power line to the trunk release actuator). That fixed me issue with the trunk actuator popping open. When I did this I did not see any other wires that were damaged or spliced, but since I don't have a spoiler, I don't really expect this to be the problem.
Just not sure if the brake pedal switch is the culprit, or if I somehow missed a fragile wire. ?
Mry
Mar 3, 2023 01:03 AM
mike730
Jan 12, 2018 04:25 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
Lsantana757
Jul 20, 2015 09:08 AM
