Bluetooth: '05 and older
Old May 23, 2007 | 06:26 PM
Texasscout's Avatar
Originally Posted by 04NismoV35
I too was looking at these. So am I understanding correctly, both the Motorola and Parrot units can be set up to play through the factory stereo?
THIS is the one I have. It has it's own speaker. It will work with your MUTE function if your radio supports it. I couldn't find a wire with the factory Blose system.
Old May 23, 2007 | 07:58 PM
Noremac's Avatar
See pics of my Parrot 3200 install in this thread:
https://g35driver.com/forums/audio-video-electronics/84546-where-mount-parrot-ck3100.html
Old May 30, 2007 | 11:20 AM
04NismoV35's Avatar
Both of your setups are using an external speaker. Does that mean that you can't set it up to play through the factory speakers? Perhaps using the same channels that the Navi uses. Noremac, your setup looks great and is bassically what I was looking for. How is the outgoing voice quality? Many people complain when I use my headset and it need to be clear since I'd be using it for mostly business.
Old Jun 1, 2007 | 02:46 AM
04NismoV35's Avatar
Anyone?
Old Jun 6, 2007 | 01:46 PM
jimmyh's Avatar
The parrot is great. It works flawlessly with my SMT5600 smartphone. If you want to hook up easily into your audio system:
http://www.installer.com
They have plug and play cables for nearly every car. If you have Bose with an external amp though, they dont always work well. Some people getting static and some popping. Supposedly there is a filter for that though. You can call them though, they are very helpful.
Old Jun 7, 2007 | 11:10 AM
04NismoV35's Avatar
Thanks for the info and site
Old Jun 7, 2007 | 05:09 PM
jimmyh's Avatar
No problem, I forgot about this one:
http://www.parrotkits.com/
Between the two, you can usually find what you are looking for. I have installed alot of them if you need any pointers.
aktif8
2nd Gen (V36) Sedan
30
Aug 5, 2017 11:47 PM
prinny
Nov 22, 2015 11:07 PM
youngdip631
V36 Interior, Exterior & Lighting
Sep 28, 2015 03:55 AM
Datsunguy
Aug 19, 2015 01:02 AM
