how to disable AWD?
Old Apr 23, 2007 | 04:17 PM
killerlexus's Avatar
how to disable AWD?
i pulled AWD fuse and the front tires still move on the dyno(it doesnt move alot, but it does start to roll slowely. is there another fuse that i have to pull also to disable the frontwheels? just want to make runs of AWD vs RWD mode in my car, to see how much power i lose through the drivetrain in AWD mode.
Old Apr 23, 2007 | 05:06 PM
ttrank's Avatar
Grocery getter
From what I know it is still a physical connection so they will move a little. My rwd does the same thing in neutral. I think the fuse is the best you can do without getting dirty and disconnecting parts.
This is not gospel. I don't have an awd so I am not an expert.
Old Apr 23, 2007 | 05:21 PM
GEE35FX's Avatar
check out threads by Neal376 or send him a PM, he has played around quite a bit with disabling his AWD system on his X.
Old Apr 23, 2007 | 08:38 PM
Neal376's Avatar
thats news to me.
there is no physical connection when you pull the AWD fuse. The G operates on a electromagnetic clutch that engages only when power is applied. when fuse is pulled and the power is cut, the clutch disengages. heck - the clutch is disengaged when you are above 30mph. must be something else
HOWEVER
vinny ten told me that even if you do pull the fuse...you should still run it on a AWD dyno....i assume he has pulled fuses before and seen this happen
hrm...mystery mystery
Old Apr 23, 2007 | 10:52 PM
ttrank's Avatar
Grocery getter
I would never run it on anything but an AWD dyno.
Old Apr 23, 2007 | 11:26 PM
it was on a AWD dyno. even with the AWD fuse pulled the front tires started to roll as i got on the throttle.
i guess big smokey burn outs are out of the question.. and thought the car would be stronger with less drivetrain loss.
Old Apr 24, 2007 | 08:10 AM
Neal376's Avatar
i do big smokey burn outs every other weekend
maybe they werent being turned by power and it was just their differencial letting them move freely
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
Danielek
May 1, 2022 01:28 PM
G35xdriver04
Nov 7, 2015 08:31 PM
NailBomb
Oct 28, 2015 07:53 AM
