KP Technologies Sedan Mirror Tilt Module
Originally Posted by chrisyoon
Will this work for manual tranny's?
From page 1:
https://g35driver.com/forums/showpos...4&postcount=39
It would be possible (all of our products are designed and built in house, so we can do whatever we want with them), but that functionality does not currently exist.
I, personally, have never ran in to a circumstance where I used the tilt function and then needed to mirror to immediately be back in to place. I typically use the mirror to park, so the delay doesn't come in to play.
However, I occasionally use the tilt mirror to back down my driveway, but again, the tilted mirror doesn't bother me because I make sure the road is clear before I back in to it.
The only time I have found that it would help is when you back up and want to turn your car off right away but need to wait a couple seconds for the mirror to come back up. I always need to let my turbos cool down so it is never been an issue.
The original prototype did, and I found that to be unacceptable, so there is now a 12vdc switched and a 12vdc constant wire - the constant wire allows the mirror to return to original position when the igniton is turned off.
The module will also NOT tilt the mirror if the car is started in reverse (great for us 6mt guys).
Now that you told me that I use it even more!
Where do i sign up for one of these things. I was waiting for one of these to come out. My prayers have been answered.
