Oil pan spacer for G35x
Old Apr 26, 2007 | 12:27 PM
Juanfunction2nd's Avatar
hey guys im a noob on the awd set up. but i have been searching and cant find any vendor that has an oil pan spacer for the g35x.. any of u now of a company that carries it thanks in advance
Juan*
Old Apr 26, 2007 | 01:18 PM
ttrank's Avatar
Grocery getter
How much room do you have below the pan? The standard spacer is ~1" but I don't know if your pan is the same or not.
Old Apr 26, 2007 | 03:05 PM
ma_sha1's Avatar
I'd imagine the X got more room down there, as it's higher off the ground?
Old Apr 26, 2007 | 04:09 PM
ttrank's Avatar
Grocery getter
My concern would be the front drive and sway bar.
Does anyone have any pics from under an X?
Old Apr 26, 2007 | 04:58 PM
Neal376's Avatar
i do and it is the same. the oil filter has a bracket attached to it that relocates it so that it is facing foward because the sway bar is in the way
its a bad pic, you cant really see from that angle at all. but I am confident that it should be fine. it seems that VRT didnt run into this issue when they built that X
Old Apr 26, 2007 | 05:13 PM
ttrank's Avatar
Grocery getter
Go for it!
Great mod. It was one of the 1st things I did. With the way the VQ burns oil you can't go wrong with an extra qt. Between my spacer and greddy pan my car holds ~6.5 now.
Old Apr 26, 2007 | 05:20 PM
Neal376's Avatar
my vq burns a tiny bit but will stay inbetween min and max on the dipstick long after by oil change interval @ 3.7
Old Apr 26, 2007 | 05:53 PM
ok the reason i ask is because i had the oil pan spacer on my 350z with turbonetics kit.
now i have the 350z awd with the x drive train and the oil pan is diferent from the RWD VQ so the oil spacer has to be design for the x.
it got finished a month ago and now im gonna add a vortech SC i need some kind of boost till the winter so i dont like taping into my upper oil pan so i want to find a spacer.. thanks guys
by the way here a pic of the car at HIN DC with my girl modeling for our company
Old Apr 28, 2007 | 05:06 PM
Neal376's Avatar
VRT dropped a TT kit (and some motor work) on a G35x in california. I forgot the username, but he does post on this website. Im quite sure VRT made an oil pan spacer for that X and maybe you can ask them for their advice.
but as far as I know, the pan itself may be different but the crank case should not!! so a spacer should fit just fine even though the X's pan maybe a bit modified to accomade the ATTESSA hardware
Old May 1, 2007 | 10:39 AM
cool thanks for the info.... if that the case im sure i can have one made... i just wanted tos ee if any one made one already
jsimonk
Dec 22, 2023 03:49 PM
zoop425
Mar 29, 2016 05:51 PM
itztwinki3
Aug 11, 2015 05:52 AM
