A 'whoosh' sound when accelarating? Air intake?
Old Dec 29, 2003 | 02:32 AM
rajanb's Avatar
I just noticed a 'whoosh' sound when accelarating at relatively low revs (2500-3000). It sounds like air intake but the sound seems to come from the right hand side of the car.
Could it be a leaking exhaust from stone damage or the tail pipe bumping the curb?
Appreciate your feedback
Old May 17, 2009 | 10:22 PM
CLEANBS's Avatar
bumpp
have the same issue
noise sounds like its coming from the air intake
Old May 17, 2009 | 10:51 PM
Mmagic76's Avatar
It's from the MD Spacer.
Old May 18, 2009 | 12:25 AM
CLEANBS's Avatar
Im stock
as far as I know lol
i bought it used, It has the engine cover, whats a easy way to tell if I have the spacer
Old May 18, 2009 | 12:35 AM
IPGSEDAN's Avatar
you have to take off the engine cover it has 4 bolts. Then look at the plenum and lower plenum. If there is nothing in between, then you do not have a spacer.
Old May 18, 2009 | 01:08 AM
Blue Meanie's Avatar
It's the air intake. I never had it before, but had it immediately after installing.
Old May 18, 2009 | 12:00 PM
CLEANBS's Avatar
i dont know if my intake or plenum is stock
Old May 18, 2009 | 12:07 PM
pwebb's Avatar
no spacer installed, and stock intake.
Old May 18, 2009 | 06:35 PM
(>")> G35's Avatar
ABS check? Does it only make the sound for a short moment and after the car has been sitting for a while?
Old May 19, 2009 | 10:39 AM
CLEANBS's Avatar
yea
Old May 19, 2009 | 06:34 PM
abailey362's Avatar
let your foot sit on the brake pedal when starting to move. you should feel it shake a little if it's the abs test
Old May 19, 2009 | 08:08 PM
jack_burton's Avatar
it's the air intake...It's designed for performance...although at a high sound cost. Remember infiniti designed the air intake/plenum very very well
Old May 19, 2009 | 08:27 PM
fishnchips's Avatar
I am pretty sure its an ABS test. cuz my friend's 06 G35 has the same sound too. my 97 Nissan Quest makes the same sound too.
if u put step on ur pedal when that sound happens, u will feel the brake rattles a little too
Old May 21, 2009 | 01:12 PM
CLEANBS's Avatar
thanks for all the replies
RA081024
Sep 7, 2015 01:29 AM
underworld
Aug 6, 2015 01:36 PM
