I think you can look in the phone book and find a place. the only place I have been to a dyno in southern Cali was Cypress where Jackson Racing is. That's where my roomate got his supercharger installed on his ITR.
Andrew
2003 coupe 6MT blue premium aero (on order)
Andrew
Ok.. Ill call em later and ask em if it was crank HP or rear wheel.. I have my dyno sheet with me so when I get to school Ill go and scan it..
pestilence
pestilence
..Registered User
If he didn't take the engine out of the car, it was wheel. I believe the machine was probably incorrectly calibrated.
Andrew
Andrew
Well G35Lin dyno'ed with me and he got 220's...so I guess it couldent be calibration..
pestilence
pestilence
..Registered User
Sure it could, it could have been incorrectly configured for your run. Unless you guys took turns with the machine settings never changed.
Andrew
Andrew
Oh okay. I GET IT NOW....
i wish i had reliable dyno numbers..
pestilence
i wish i had reliable dyno numbers....
pestilence
..Pesti,
If they won't refund, let them re-do. Seems they did ok with G35Lin's so they've 'got it in 'em'. [img]/w3timages/icons/smile.gif[/img]
Gsedanman's Coupe
Gsedanman's CoupeRegistered User
I can't believe that I read this entire thread and no one else has pointed this out yet: Your post indicated that your dyno was done in 3rd gear. My limited understanding of the dyno process is that in order to achieve accurate results, you must dyno in 4th gear on the 5 speed auto because that is the only gear with a 1:1 ratio. I believe that your impossibly high numbers are caused by dynoing in 3rd gear instead of 4th.
Yes and No. He should have done it in 4th gear, but, the machine can be calibrated to do it in 3rd gear. Most accurate dyno results are as you stated, from the 1:1 gear. However, I believe his were inflated from incorrect machine calibration.
Andrew
Andrew
hmm.. What does it mean by what gear its done in?
Meaning the car is in 4gear at all times? or it stops at 4th gear? ..sorry.. dont know much about dynojets..
pestilence
pestilence
Re: MY STOCK G35 DYNO
When the guy did mine he was in 4th gear the entire time. He spins it up and at about 2krpm or so he mats it and runs it up to redline, then allows it to spool down. You get a curve of HP and Tq vs. RPM. Some have done dyno runs where they shift gears but I have no experience with that.
hmm.. It looked like this guy was shifting... anyways ill call them and ask.
pestilence
pestilence
..w00h00... finally... got off my lazy @$$ and got it scanned..
pestilence
pestilence
..Pesti, I don't pretend to know too much about dynos, but the average peak looks more like 210 - 215 H/P. The 240 - 250 looks like the spikes which I would say are shift points. NO?
Torque looks like 220 or so. Aren't these #'s about right for the Sedan?[img]/w3timages/icons/smile.gif[/img]
<font color=red>Gsedanman</font color=red>
