I need help from you Rim/Wheel Gods! Please advise!
Old May 6, 2007 | 08:56 PM
Empz's Avatar
Hey guys,
I've decided this is the season I'm getting my rims ... I have a 2005 G35x in Ivory Pearl. I'll keep the rims secret for now ... but I need to know if these will fit.
I'll be buying ONE of these sets, will these FIT?
19X9.5 +45 Offset (All around)
19X9.5 +38 Offset (All around)
20X8.5 +35 Offset (All around)
Thank you so much in advance!
-E
Old May 6, 2007 | 10:03 PM
(>")> G35's Avatar
19X9.5 +45 Offset (All around) - NO, would only fit the rear if you wanted staggered setup, but you hacve a G35X, so you would have to disable AWD.
19X9.5 +38 Offset (All around) - NO
20X8.5 +35 Offset (All around) - YES
Old May 6, 2007 | 10:59 PM
Empz's Avatar
Thank you so much!
Will 19X8.5 fit? Both +38 and +45?
-E
Old May 7, 2007 | 12:51 AM
(>")> G35's Avatar
Both will do fine, the +45 would look a bit more tucked. I would go with the +38.
Old May 7, 2007 | 02:47 AM
G SEDAN's Avatar
i second that 19x8.5 with +38 will have a much more cleaner line up witht he fenders go for it!
Old May 7, 2007 | 05:44 PM
Empz's Avatar
I'm leaning towards the 20x8.5 +35 Offset. Getting a killer deal on 20" ... what do you guys think?
Will this setup rub? I will be lowering the car with Eibach Pro-Kit.
-E
Old May 7, 2007 | 07:16 PM
ttrank's Avatar
Grocery getter
-E
You should be good. The fronts might rub a little.
Most people will say they won't but my car is a bit strange because my 20x8.5" +40 fronts rub a little.
They will look about like this. Here is my car back when I had 20x8.5 ~+38 all around. This is on H&R springs which are a little lower than the eibach. Wow, that was two sets of wheels in the past.
esotericrider
Feb 14, 2022 07:19 AM
jbmw002
Sep 10, 2015 12:54 AM
Dmill86
Sep 6, 2015 08:14 PM
