windshield cracking noise in 2003 sedan
Old May 17, 2007 | 03:57 PM
shorswill's Avatar
My G35 2003.5 sedan windshield is making a cracking noises when I go over bumps. It sounds like it is coming from near the dashbooard but I think it has something to do with the windshield. What is weird is that it disappears when the windshield is wet. Its like a fluid acts as a lubricant. It may have started as a result of going through a carwash with rust inhibitor in the spray. I stumped. Has anyone experienced a similar noise? ITS REALLY ANNOYING.
Old May 17, 2007 | 04:04 PM
wreckeds2k's Avatar
Welcome to G35driver, HOWEVER you are in the wrong section for this ?? Look at the 03-6 G35 SEDAN SECTION.. or do a search.. I personally have never heard such.
Old May 17, 2007 | 04:28 PM
gqong's Avatar
hmm you sure its the windshield? it may be your swaybar endlinks are gone...if is it that it does create a similar sound.
Old May 17, 2007 | 09:36 PM
ttrank's Avatar
Grocery getter
I don't think it is the w/s.
Old May 18, 2007 | 08:28 AM
sdnpaul5at's Avatar
There's a tsb on that, it's the plastic piece on the base of the windshield on the outside, you have to remove it & add felt tape on the actual clips, worked for me.
Old May 18, 2007 | 09:33 AM
ron4row2's Avatar
+1 I think this should take care of it.
Old May 26, 2007 | 02:50 PM
shorswill's Avatar
Cracking noise solved. After talking to the a service tech he suggested checking the wiper assembly since it was replaced and not the original. Took the cowl off (4 bolts and a variety of clips). Took off the wipers. Removed the wiper assembly (4 more bolts). Put a piece of cork or celluous/rubber fibre pad where each bolt screws to a mount and under a few clips. I did not use adhesive but it probably would have been a good idea. It looks like foam pads with adhesive backing were previously installed but not on all the mounts. Screwed everthing back down and presto, no cracking or snapping noises. A great quiet ride again.
mcneil_g35
Aug 5, 2015 12:03 PM
joedaddy1
Jul 28, 2015 02:58 PM
rping
Jul 26, 2015 09:53 PM
realtalk21
Jul 20, 2015 09:07 AM
