Sedan SRS airbag light - spiral cable damaged?
Old May 22, 2007 | 01:08 PM
clinthammer's Avatar
The light came on for the 4th time - today the dealer saw it on and checked it out. Few hours later after a complete check - he said the spiral cable is damaged and it can take anywhere from few days to 2 weeks (from japan) to get the cable..
I wished it was the sensor but nope...
What is the purpose of this spiral cable?
Old May 22, 2007 | 01:24 PM
wreckeds2k's Avatar
Its so you can turn the steering wheel and still have function of the electronics.
Otherwise known as a CLOCKSPRING... Let a pro put it on or you will be back in the same trouble.
Old May 22, 2007 | 01:28 PM
well aside from the flashing srs light, everything else worked fine..
Old May 23, 2007 | 02:47 PM
ttrank's Avatar
Grocery getter
That's good. It's an easy fix.
Those don't go out too often unless you unhook the steering and turn the wheel a few times.
Old May 23, 2007 | 02:51 PM
well that's what the service guy said. he's like it only happens when you remove or modify your interior. I told him numerous times that its not modified and im sure you tech can see that.
he also knows the only mods i have are performance. No JDM nissan logo airbag
anyways i questioned him as to the purpose of the spiral cable and he said the airbag is connected to this cable. This cable terminates on a small plate which has a sensor - plate connected to the wheel. Hence when I turn the wheel sometimes the plate gets loose and srs light is on.
Resetting kills the light but again if the plate is loose the light is on.
The part will be in either in a few days or 10 days frmJapan. However, I just had to get my G back because I could not bear to drive the loaner Mitsu Lancer 1.3 anymore.
We dont get Infiniti loaners here
Old Jul 21, 2007 | 11:19 AM
update: car went in last week for service and they changed out the spiral cable. airbag light is off now and all is well
Old Jul 21, 2007 | 01:41 PM
ballisticus's Avatar
This happened on our LS400 after 200000 miles. 2 weeks wait isnt bad, we had to wait for a month to get the part. Nothing worked on ours though, no airbag, no horn, no cruise. The wire that powers the whole steering column had snapped. Bad design, they should have parallel PWR/GND so you dont lose everything. Especially a safety item like the airbag.
Old Sep 2, 2007 | 05:13 PM
Jining's Avatar
any idea how much the sprial cable replacement was?
Old Sep 3, 2007 | 02:51 AM
no idea as it was under warranty.
Old Dec 20, 2010 | 02:22 AM
bump - cable damaged again and cost is AED 699 (1 US$ = AED 3.68) for the part!! grrrr!!!
Old Dec 20, 2010 | 02:25 AM
thescreensavers's Avatar
Mr.202?
^ how does your keep getting damaged?
Old Dec 20, 2010 | 02:29 AM
lol I don't know.
Old Dec 20, 2010 | 02:36 AM
Mr.202?
^ I would look into it ha, seeing as your car is eating them :P
just going to replace it. Can't be bothered as I shall be selling my ride in a few months.
Old Dec 20, 2010 | 02:46 AM
Mr.202?
^ ha that would fix it on your end :P
