Playing CD-R's in CD player
Old Feb 6, 2003 | 07:09 PM
GetGo's Avatar
Just got my G35 and I was reading about people having trouble playing CD-R's in the CD player is this true, how many people are having trouble?
Old Feb 6, 2003 | 07:55 PM
ryoken's Avatar
Re: Playing CD-R's in CD player
My service manager says that, officially, it can't play CD-R's, and they might cause the player to jam.
You don't want your player to jam, mine did on Jan 8th (though I wasn't using CD-R's, just standard store-bought music CD's), and they finally got a replacement radio in for me today (Feb 6). They're swapping it out tomorrow morning. I have the Bose system, which is apparently backordered. The base system supposedly doesn't have a big jamming problem, and isn't backordered.
Old Feb 7, 2003 | 09:27 AM
mruae's Avatar
I play CD-Rs in my cd player all the time. i have no problem what so ever. the odd time you will hear some noise from the speakers but otherwise i have no problem playing CD-Rs.
Old Feb 7, 2003 | 09:53 AM
Gordgee's Avatar
Administrator
No problems with CDRs. I had a CD out from the library once that refused to load.
I can't see that CDRs would cause the player to jamb unless it has one of those applied labels. The player should simply refuse to play it because it can't read the data if it otherwise has a problem.
Old Feb 7, 2003 | 10:11 AM
ryoken's Avatar
I agree with your logic, I'm just passing on the little gem that my service advisor dropped on me. My wife's Jeep can't play CD-R's very well, but it certainly has no problem spitting them back out.
Old Feb 7, 2003 | 10:44 AM
IQ9's Avatar
IQ9
My only problem is that the CDRs can confuse the player. It starts on track 1 but decides it doesn't want to play that one and randomly plays another. This only happens using CDRs. It will sometimes pick another disk entirely after playing half a song off a CDR.
03.5 Sedan/B. Silver/Premium/Winter/Aero
69 Chevelle BB/4.11's
Old Feb 7, 2003 | 11:03 AM
dyenboy's Avatar
Registered
I have had 1problem, playing my cd-r's...On Disc 5, sometimes it doesn't read it, but I eject it, clean it off, and it works...
Old Feb 7, 2003 | 03:20 PM
pestilence's Avatar
I use the Memorex Black cd-r's and they have worked flawlessely...
I think that if people label their CDrs they have more of a chance getting stuck becuase of the adheasive.
..pestilence..
Old Feb 7, 2003 | 03:56 PM
IQ9's Avatar
IQ9
My suburban hates CDRs with labels they won't play at all-GM deck though.
Old Feb 7, 2003 | 06:38 PM
Rumble's Avatar
In my 6th disc, it makes a ticking sound along with the music. It's happened with different CDs, but doesn't make that noise when I play those CDs on another player...weird.
It's still a G thang!!
Old Feb 7, 2003 | 07:14 PM
dyenboy's Avatar
Registered
Mine does that ticking thing too...I notice that it happens at the end of the last track, which looks like its saying..its gonna go to the next Disc...It doesn't happen when its on repeat or any of the other options...
Old Feb 8, 2003 | 04:39 PM
GetGo's Avatar
Hey pestilence Can you give me more details on the Memorex CD's you use. I would like to buy them, I was in Comp USA today and saw Memorex CD's but I did not see anything in black. Can you help...
2003 G35 Sedan Desert Platinum/Black Premium/Sunroof/Winter pkg
Old Feb 8, 2003 | 08:16 PM
mrpagaldesi's Avatar
cd-r's work fine for me .. perhaps there is problems when burning the cd so the cd player won't play . try using a program called NERO ... it has one of the best wizards i've seen and it helps u thru the burn process with no trouble .. and it will tell u if the cd burned correctly or not . so that a good sign as well ..
' 03 G35s
Old Feb 9, 2003 | 10:51 PM
VQ_POWER's Avatar
i use a yamaha 24x burner with fujifilm cd-r's. IT came packaged witth the nero software and works flawlessly. I find that fujifilm and memorex have the best compatability rates among cd-playing devices. Verbatin has come out with new vinyl cd-r's but i havent tried them yet. They are supposed to offer better compatability, even with the oldest cd-rom's. If your using a burner, i would opt for yamaha or plextor. They usualy rate the highest, and yamaha has a mode called "audio master" where the copies are better than the originals . Well, thats my 2 cents worth of advice
Old Feb 11, 2003 | 11:45 AM
hoshtaylor's Avatar
FYI...I tried 4 different kinds of CDs burned from two different burners and apparently the only CD that works (I haven't tried the Fuji or Memorex though) was Maxell CD-R Pro...they play fine burned from either of my burners...no problems playing on any cd player, obviously including the Bose in my G.
