Unusual noise at start-up
Old Jun 2, 2007 | 11:21 AM
plutonium239's Avatar
I'm betting this has been covered ad-nauseam but I did some searching and could not find any posts describing what my car is doing. When I start the car, just after the engine idles down, occasionally I hear a quick rattling noise. It's been doing it for a while. My dealer kept the car for 2 nights and could not replicate the noise. Oddly enough, my father reports that his 03 Maxima does the same thing. Then last week I looked at an 07 Coupe. When the salesperson started the car, I again noticed it. Just to clarify, when I turn the key and the car comes to life, the revs will come up for a second then settle down to idle speed. The noise occurs just as the revs are falling to idle. It really sounds like 2 gears slightly grinding or a piece of metal that is loose, rattling around somewhere. Am I going crazy?
Old Jun 2, 2007 | 11:49 AM
HLMAX's Avatar
If you can feel some vibration on the brake pedal, it is the ABS self-test. It sounds like a rattle.
Old Jun 2, 2007 | 12:20 PM
I thought this occured when the car is in motion, at very low speeds. I can feel that happen when I get rolling, I'm fairly certain this is something different...happens only when the car is stationary, just after the starter disengages the flywheel.
Old Jun 2, 2007 | 10:29 PM
ttrank's Avatar
Grocery getter
Are you sure it is not some back pressure in the exhaust causing a rattle in the cats or maybe even flywheel chatter?
Old Jun 2, 2007 | 11:09 PM
Dudefish's Avatar
It's caused by a little slack in the timing chains before the tensioners pump up with oil.
Old Jun 3, 2007 | 12:28 AM
SkydiverTilt's Avatar
i've had it happen once...never again, but i know what you mean.
Old Jun 3, 2007 | 11:10 AM
Ah...that would make sense. This would explain why it only happens when the engine is cold. Can you tell how you found this out? I ask because even my Infiniti service dept. was unable to tell me this.
Old Jun 3, 2007 | 12:31 PM
Dudefish's Avatar
I honestly don't remember if I read that, if someone told me that authoritatively, or if it's just my educated guess, but that's what I think it is. The link posted by Treacherous looks like it's describing a similar phenomenon, too. Mine (04 6mt sedan) only does it occasionally, and I think I understand what it is, so I don't consider it a problem.
Old Jun 3, 2007 | 12:44 PM
Well either way, thank you very much! I originally thought the starter gear was hanging up on the flywheel and was certain I would be stranded some day. I feel much better now.
Old Jun 4, 2007 | 02:26 AM
joedaddy1's Avatar
dang i have the problem.. but i guess it isn't really a problem.. it happens about twice a week
Old Jan 8, 2008 | 07:30 PM
nadir's Avatar
my maxima did this ... it was the timing chain ... did it when I was low on oil, had dirty oil or on a really cold morning ...
it goes away after a while.
I've heard it once on my G as well.
Old Jan 8, 2008 | 07:38 PM
HUMBOLDT_G's Avatar
I don't know about our G's but this sounds like the starters bendix drive not releasing quickly and getting hung up a little before it recoils back into the starter housing! Just my 2 cents
Old Jan 8, 2008 | 08:16 PM
ttrank's Avatar
Grocery getter
So my sound is a small exhaust leak at the manifold. As soon as the car warms up a little it expands and goes away.
The motor is coming back out in a month or so anyway.
Old Jan 9, 2008 | 11:54 PM
psedog's Avatar
Back in SD**
Yeah, keep rubbin' it in why don't you
To the OP, sorry for getting of subject. This is an interesting issue. I never noticed it. Although, now I'll probably notice it in the morning.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
Jeff T
Sep 30, 2015 02:00 PM
alinero718
Sep 27, 2015 09:35 PM
