battery drains in 24 hours
Old Jul 27, 2007 | 06:55 PM
TheTrance's Avatar
I have this weird problem that my battery drains in a day and the car wont start. it cant be the battery since its brand new. any ideas??
Old Jul 27, 2007 | 07:02 PM
ttrank's Avatar
Grocery getter
Do you have an aftermarket alarm?
There was another problem like this some other people had but I don't remember what the cause was. Might try a search.
Old Jul 27, 2007 | 07:04 PM
TheTrance's Avatar
no alrams.... i called the dealer and they actually asked the same question...probably have to end up taking it there....
Old Jul 27, 2007 | 07:25 PM
rcmakers's Avatar
Do you have the Bose System. My wife's 03 had the same problem. When they ran their diagnostics test they found out that there was a short within the radio and that it was causing the battery to be drained.
Old Jul 27, 2007 | 08:25 PM
TheTrance's Avatar
yeah i've got the bose unit still. so did they replace your radio? how much?
Old Jul 27, 2007 | 09:16 PM
rcmakers's Avatar
It was actually covered under the warranty. But from what I remember they had to replace the CD unit. I would probably disconnect the power to the radio and see if the battery drains.
Old Jul 27, 2007 | 09:20 PM
StarChamp's Avatar
How do you know your battery is draining? Maybe it's not getting charged? Have you had your alternator checked?
Old Jul 27, 2007 | 10:01 PM
TheTrance's Avatar
i charge the batt manually with a charger. the car starts and runs fine after charge but if i leave it overnight it wont the day after
Old Jul 27, 2007 | 10:16 PM
tomparker22's Avatar
+1 sounds like it could be your alternator
get that checked
Old Jul 27, 2007 | 10:22 PM
ttrank's Avatar
Grocery getter
So the battery is not new?
That may still be the problem. It might take a charge but not be able to hold it. Did you check the water level?
Old Jul 27, 2007 | 10:29 PM
RBull's Avatar
Rated M
You obviously have a short in the system which is drawing constant power even when the ignition is off. That's draining your battery.
The dealer should be able to find the power draw and correct it.
Old Jul 27, 2007 | 10:58 PM
TheTrance's Avatar
ttank yeah the dealer replaced the batt 3 months ago so its new.....
Old Jul 28, 2007 | 08:42 AM
StarChamp's Avatar
Exactly my point. You charge it with a charger, and the car starts and runs. But if the alternator isn't charging the battery while you're driving, by the end of the day you could have a dead battery (depending on how much you drive, ICE, etc.), and you'd have to charge it again manually. Or, like somebody else posted, there's a short that's discharging the battery, most likely a bad ground. If the battery were the problem, it wouldn't take a charge no matter how you charged it.
Old Jul 28, 2007 | 10:10 AM
Dan in St Louis's Avatar
Can you pull the fuse that protects the radio and see if that circuit is the problem?
Old Jul 28, 2007 | 11:52 AM
Pska's Avatar
I had this problem twice. once was alternator and they replaced under warranty. The other time it was my daytime running lights staying on indefinately. I realize that DRLs are only in Canada, but I see you're from Alberta. It was the DRL Module that was screwed and it was hard to tell wtf was happening cuz I'd park at work during the day and not notice the lights on... either was it was fixed again under warranty.
