How to dyno with the 5AT?
Old Jul 30, 2007 | 06:31 AM
MM_G3520's Avatar
Hey guys,
I plan on dynoing my 03 5AT soon, but I am not sure what to expect. Im not talking about the numbers, but the ability for the tiptronic to hold a gear. On my model, if I put it in manumatic and into second at around 20mph the car will downshift into first when I floor it. This happens at every speed when there is the option for the transmission to downshift to a lower gear for faster acceleration.
On the dyno, when I want it to stay in fourth, I am afraid that it will just downshift back into first once the pedal goes down.
How do members with 03's dyno their cars? Is there a way to avoid this, or is this a non-issue?
Thanks for the help
Old Jul 30, 2007 | 07:09 AM
Nismo G's Avatar
Why did you post 2 threads?
-Sean
Old Jul 30, 2007 | 08:12 AM
MM_G3520's Avatar
I didn't see the dyno/tuner section until after I posted this one, and I figured I might get more answers there so I posted it up.
Old Jul 30, 2007 | 01:45 PM
ttrank's Avatar
Grocery getter
Hmm I'm not sure how they do it. I would send a PM to some of the 5AT guys and ask.
Old Jul 30, 2007 | 04:30 PM
sloppymax's Avatar
the easiest thing to do is take it on the highway, put it in the gear you want and test the rpm to see where it will not downshift. i dynoed in both 4th and 3rd in my auto. i remember for 4th, i ran it to about 60mph (dont remember the rpm) and went wot from there. make sure they hit the rev limiter (fuel cut) in whatever gear so you the full rpm range.
Old Jul 30, 2007 | 08:36 PM
OCG35's Avatar
pre 04.5 ATs are tricky to dyno... mine holds gear by I have heard of 03s having problems... PM DaveO he'll give you the details of what to try.
Old Jul 31, 2007 | 02:28 AM
MM_G3520's Avatar
thanks guys, this helps a lot!
seagrasser
May 3, 2022 09:43 AM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
Gwhut?
Drivetrain
Sep 6, 2015 10:07 AM
TrillO.G.35
Sep 5, 2015 02:06 AM
