Stock Engine Cover
Old Aug 11, 2007 | 05:16 PM
jimmykce1's Avatar
Stock Engine Cover
How much heat does the stock engine cover hold in? Would it be better to remove it all together??
Old Aug 11, 2007 | 05:24 PM
izmir41500's Avatar
G35driver Addict
probably better to remove it, but then you have the hood holding in the heat too. so it will make a marginal difference in temp, if any.
did the 06 sedan come in twilight blue like it says in your sig?
Old Aug 11, 2007 | 05:25 PM
sloppymax's Avatar
i agree that is better to remove it from a heat stance. there will still be heat under the hood obviously but it will not be concentrated on top of the manifold.
Old Aug 11, 2007 | 05:27 PM
ttrank's Avatar
Grocery getter
This has been covered many times before and there is very little benifit to taking it off. The best option is the Z style one to give some good looks and still allow the heat to move around a bit more.
Old Aug 11, 2007 | 05:32 PM
jimmykce1's Avatar
Yes it does.
Old Aug 11, 2007 | 05:33 PM
jimmykce1's Avatar
I was looking to install a Stillen strut tower brace on my sedan which said that it will not allow for any type of engine cover once installed.
Old Aug 11, 2007 | 05:45 PM
ttrank's Avatar
Grocery getter
I would go with Richies which will fit with the engine cover. I think it will fit with a spacer and engine cover.
Old Aug 11, 2007 | 05:58 PM
izmir41500's Avatar
G35driver Addict
richies rubbed on my engine cover so i took the cover off. it also rubs by hood liner.
Old Aug 11, 2007 | 06:05 PM
G SEDAN's Avatar
This is what I did to the richie bar since I had a crawford plenum. I painted the engine cover gloss black +clearcoat to match the bar I painted and aslo cut the cover to fit around plenum. Excuse my dirty engine bay though haven't cleaned it for years. I have the bar at the lowest setting and it doesn't seem to be rubbing engine liner.
jsimonk
Dec 22, 2023 03:49 PM
ghost_g35
Aug 7, 2015 10:31 AM
joedaddy1
Jul 28, 2015 02:58 PM
newg37
Jul 26, 2015 09:32 AM
