Aluminum Door Trim Dented - How to Replace?
Old Aug 19, 2007 | 03:10 PM
dschaefer's Avatar
Got a nice 1/2 inch dent in the aluminum trim on the driver door. I have searched but cannot find the how-to on removing this piece or anywhere other than the dealer to buy a replacement... anyone?
Attached Thumbnails Aluminum Door Trim Dented - How to Replace?-img_0077.jpg
Old Aug 19, 2007 | 05:07 PM
darnelled's Avatar
You will probably need to buy a new peice. I wanted to pull off all the chrome parts to have them painted to match the rest of the car, but the bodyshop said the clips holding them on usually break when removing them and the whole peices must be completely replaced.
Old Aug 19, 2007 | 07:03 PM
dschaefer's Avatar
I assumed it would have to be replaced -- I need to know how to get it off and if there are any better sources for the replacement part than the dealer.
Old Aug 19, 2007 | 10:16 PM
GixxerSteve's Avatar
Riverside Infiniti quoted me $21.95 plus shipping for one aluminum door cap.
Old Aug 21, 2007 | 10:08 AM
dschaefer's Avatar
Anyone able to tell me how to remove the aluminum trim on the bottom of the driver window?
Old Aug 21, 2007 | 10:25 AM
da mayor's Avatar
it clips right now... just slowly take a very thin pic and pull it out
Old Aug 21, 2007 | 10:37 PM
OCG35's Avatar
the aluminum trim around the doors are VERY VERY expensive... It can be removed and replaced if you are VERY careful... have a Qualified reputable body shop do it and you should be fine.
To the OP about dent - if it's real bad you'll probably need to replace it - the aluminum is so thin that any attempt to work it back into shape will most likely make it worse...
I went through all this a couple of years ago to do this to the car... this was plan D by the way, the first 3 ideas wouldn't work - which were black chroming, the guy that does my emblems wouldn’t do the trim (even though I have found a resource that might work since then, too late for me now), second choice was powder coating a black chrome color (molded plastic behind the aluminum nixed that idea - didn’t know until trim was off the car), 3rd choice was anodized (since the pieces were off I had to do something, but the belt molding has molded rubber and most anodizing shops wouldn’t do it, a couple said "maybe" but wanted test pieces to try first - I didn’t have access to "test pieces" and the car was sitting at the body shop for several days by this time)... final decision was paint.
Here's how it turned out (pic below) - not what I wanted, but I still like it better than the polished aluminum (for my car)... The car has a grey theme, which is why I went through so much trouble (believe me it’s a PITA!!!)... there is nothing shinny on my car (no offense to anyone else, I've seen cars that look great with polished aluminum all over and chrome - I just went a different approach).
jsimonk
Dec 22, 2023 03:49 PM
tiguy99
Mar 1, 2016 11:42 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
