Synthetic GL-5 in tranny
Old Aug 21, 2007 | 08:47 PM
canucklehead's Avatar
I had my '04 6mt sedan serviced (54k kms) recently and had the manual tranny fluid changed out for Pennzoil Synthetic. After consulting a local Infiniti dealer, my garage used 75W-90 GL-5. GL-5 was specified by the dealer.
The manual calls for GL-4, so does searches in Driver and elsewhere online. With this info I phoned the local dealer and was told the same as my garage, they use GL-5.
Should I be concerned with the fluid installed? Do I need to drain the GL-5 and put in some GL-4?
Any constructive advice is appreciated, thanks.
Old Aug 21, 2007 | 10:23 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
replied to your thread in the Canada section.
-GP-
Old Aug 22, 2007 | 01:22 PM
thanks.
since the fluid change the shifting has been noticeably more notchy, not nearly as smooth.
i have read that the GL-5 has higher shear resistance and is "slicker" than GL-4. this counteracts the synchros (which need some friction to work properly) and causes more grinding.
i am leaning towards draining the brand new (and expensive) fluid out and finding some GL-4. even though GL-5 may be good fluid, the long-term effects of rougher shifting concern me.
Old Aug 22, 2007 | 01:59 PM
Gsedan35's Avatar
Read this thead,
http://www.my350z.com/forum/showthre...&highlight=gl5
I'm running a blend of gl4 redline oils, though I won't sit here and tell you that just a fluid change made a so so tranny suddenly shift better. Polishing the shifter ball, cup and bearing sufaces, that did make a differance, but inside the box it's business as usual.
Old Aug 22, 2007 | 04:18 PM
G35m@'s Avatar
I just got a quote from the dealership for $189.00 to flush my trans - jump in cost is due to the need for J-Matic fluid @ $10/qt. Anyone else had similar pricing on the newer G's?
Old Aug 26, 2007 | 05:29 AM
abunai's Avatar
mynimso.com has matic-j for 6.95 a quart
seagrasser
May 3, 2022 09:43 AM
MrIP35
Oct 25, 2015 11:13 PM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
celwin
V36 Engine, Exhaust, Drivetrain & FI
11
Sep 28, 2015 03:52 AM
DRG35R
Sep 16, 2015 05:33 AM
