G Tech Pro SS, advice?
Old Sep 24, 2007 | 03:13 AM
MM_G3520's Avatar
New pics, videos, and a quick question on G-Tech Pro SS!
Hey guys,
I just sent payment to another forum member for a G-Tech Pro SS. I am wondering if anyone has had experience with the g-tech, and if they can give me any feedback. Is there a yaw factor I have to enter in? Are the times generally accurate? How much lower is the hp reading from the g-tech as opposed to advertised hp or in comparison to rwhp? I've wanted one of these for a while, so it's exciting to see what it says about my car.
I have an 03 base sedan with the mods listed in my sig (1/2" Motordyne spacer, Z-tube, Amsoil high flow filter, Coupe mid-pipe), and I look forward to seeing if the lighter weight makes any difference.
Thanks for any help!
Old Sep 24, 2007 | 12:49 PM
MM_G3520's Avatar
no one? damn!
Old Sep 24, 2007 | 05:47 PM
G35xBlackawd04's Avatar
I've had one for a couple years now and I think they're great. I first had it in my 1990 Corvette. I mainly got it for the rpm gauge and shift lights. That part worked great for me as my tach didn't.
I have tried it out in my 1 month old g35x and recorded a 0 to 60 of 6 sec. I believe that they are fairly accurate based on experience and what I've read on the Vette boards.
Even if they aren't completely accurate they are a lot of fun to play around with as they have lots of options and allow you to practice for the dragstrip.
I think that they may be best used to measure performance after upgrades.
Old Sep 25, 2007 | 12:03 AM
MM_G3520's Avatar
awesome, i look forward to using it.
Old Sep 25, 2007 | 04:14 PM
DaveB's Avatar
I've borrowed them at the 1/4 mile strip just to see how accurate they were. Overall, it's been my experience they read about .2 seconds quicker and 3mph faster than what you're real timeslip will say.
Old Sep 26, 2007 | 11:41 AM
maximumvette's Avatar
I had this conversation when I had mine and remember calling some one,, not sure if it was the vendor or them directly,,, this was about 5-6 years ago. I did the same comparison at the drag strip and results were much the same as DaveB mentioned. They explained that the mph at the drag strip was an average mph going thru the speed trap and the Gtech was mph at the 1/4 mile. Also, as far as elapsed time, the gtech is not affected by deep staging or shallow staging and according to them was more consistent.
Old Sep 26, 2007 | 11:59 AM
Dan in St Louis's Avatar
How long is the speed trap? 66 feet? I have trouble believing the car's speed changes much while passing through it.
Old Sep 26, 2007 | 12:03 PM
yeah,, me too but thats what I was told. 66 feet sounds about right.
Old Sep 26, 2007 | 02:59 PM
DaveB's Avatar
The strip averages the mph of last 66'. The G-tech reports the ending speed. When I cross the finish, my speedometer reads a a few mph over 100mph, but the slip says 99ish. For whatever reason, G-techs consistently spit out much higher trap speeds than what you'll at the strip. My Maxima would run 14.3-14.4@98-99mph, but the G-tech would say 14.1-14.2@101-102mph. The same goes for the magazines since they use fancy G-techs to get their times.
Old Sep 26, 2007 | 04:33 PM
OK, then, 100 MPH is 147 feet per second. Thus 66' would take 0.45 seconds.
Our cars can probably manage about 4 MPH increase every second at 100 MPH, so from the beginning of the 66' trap to the end would gain about 1.8 MPH. But remember that the trap speed is an average over the length, so the speed at the end is maybe 0.9 MPH better than the average. Call it 1 MPH in round numbers.
Your suggestion of 3 MPH difference isn't very far off!
prinny
Nov 22, 2015 11:07 PM
AJC128
Nov 1, 2015 11:55 AM
6spdGspot
Oct 5, 2015 01:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
