2003 Bose radio/climate HU for coupe, fit in a sedan?
Old Sep 24, 2007 | 09:28 AM
sergio3986's Avatar
Would the 2003 Bose setup from a coup model, fit in a 2003 sedan model?
I have a sedan, and can get a good deal on a bose HU, but it's from a coupe. Just wondering if it will fit.
Thanks in advance
Old Sep 24, 2007 | 09:42 AM
Hi-TechG35's Avatar
Yes it will.
Old Sep 24, 2007 | 09:47 AM
sergio3986's Avatar
Awesome thanks!!!
And sorry to ask again...but one other thing. I have an early release G35 2003, so it does not have the SAT button on it, the one I want to swap in has a SAT button.
Can this be done? Will it still work? Does ti also mean I have the option to swap in this newer Bose HU, and install a compatible SAT radio option???
I'm swappign the HU because I have a bad circuit board on mine, and dealer is not replacing it and wants serious cash for it
Would be cool, if I can just swap in this new HU, and then wire up the needed equipment to have SAT radio...If anybody can answer this, please get back to me. Huuuuge thanks!
Old Sep 24, 2007 | 10:36 AM
Gilley's Avatar
The new radio with the SAT button should allow you to have sat. radio, but you may need a new finisher if yours doesn't have the hole for the SAT button. To add sat. radio, you will also need the cable to run to the trunk to connect to the sat. tuner. If you want sat. radio, you might as well get it and install it at the same time because you will need to remove the radio to plug in the new sat. cable in the rear of it.
Old Sep 24, 2007 | 10:46 AM
sergio3986's Avatar
Excellent. Just what i wanted to hear. It comes with the trim, so I house be good for that. I'm assuming most people put eh antenna on the rear dash somewhere, I'll have to go check out a couple G35 that have it already.
So I'll have to get the sat kit along with the wire harness as mine won't be pre-wired for it, since I never had it.
Old Sep 24, 2007 | 10:56 AM
Gilley's Avatar
In addition to the new radio, you will need the sat cable, the sat tuner, and an antenna.
In my G coupe, I have the sat antenna under the rear window. On my G sedan I mounted it at the edge of the trunk, next to the rear window, which required more effort.
Look for the tuner and cable at www.everythingg35.com.
EnCr1pt3d
Jul 8, 2019 02:48 PM
teamghost
Jul 28, 2015 04:52 PM
realtalk21
Jul 20, 2015 09:07 AM
