Help I need Help
Old Oct 3, 2007 | 05:30 PM
FlyingLumpia's Avatar
I am on 350z tein s-techs up front. Thanks for you help guys. I might be about to get all fronts from a coupe which is 19. It should clear right, or maybe the 18 since they clear brembo.
Old Oct 3, 2007 | 05:34 PM
G SEDAN's Avatar
all fronts would be what...8.5 +33 all around? It might rub a lil bit if i can think back. I test fitted the rears on the front when i had the coupe 19s
Socal I was thinking the same thing, or maybe the caliper is not as big who knows. Well its back to stock and I am going to have to wait until my friend gets back from Cali to try again. I kind of wanted to get rid of the 20's anyways but they do look good on my car. LOL
Old Oct 3, 2007 | 05:36 PM
G SEDAN's Avatar
Do you know how to bleed brakes? If you do then DIY! Cato has a write up sticky in the tech area. Yeah 20s are good looking alright but once you try some light weight wheels you can deal with the downgrade in size
Old Oct 3, 2007 | 05:38 PM
Jeff92se's Avatar
Red Card Crew
Running 4 fronts with the 225-40-19 oem tire size would clear fine IMHO. I'll guess 235-40-19s all around would clear too.
We discussed this Lumpia. Did you check out the clearances on my car when you were looking at it?
Old Oct 3, 2007 | 05:43 PM
Yeah, I know the front will work since they are 19X8 with a 30 offset I believe. I am just thinking will they clear the caliper, that is my main concern.
Old Oct 3, 2007 | 06:31 PM
G35Papa's Avatar
Good excuse to get some new rims
Old Oct 3, 2007 | 06:36 PM
I just wish I was a baller. Looks like I might be putting up the Sevas up for sale here soon.
Old Oct 3, 2007 | 06:48 PM
Jeff92se's Avatar
Red Card Crew
I wish I was a little bit taller. hehe
Old Oct 3, 2007 | 07:32 PM
Yeah, you seen me in person. LOL
Old Oct 4, 2007 | 01:42 AM
Yeah I dont get it, Tims looks like it clears it no problem and here is a Z with brembos and still no problem. Are the Wilwood caliper that big.
Old Oct 4, 2007 | 02:06 AM
terrycs's Avatar
Does Sevas make a version of your wheel style with the face cut for big brakes? That could explain the fit on another car.
Old Oct 4, 2007 | 02:18 AM
Well I know on the Z its a 25 offset I believe, but for Tims car he has the racing brake 4 pot caliper and he posted that it barely fit, it could be the style of the wheel for his. Mine seem to curve in more.
Old Oct 4, 2007 | 02:23 AM
terrycs's Avatar
Try this ...
Get the profile template from your BBK manufacturer (possibly their website). Stick it into your wheel and you will know how much spacer you need. Make sure you add in a few millimeters for spoke clearance.
Then do the math (assuming you know your wheel / tire specs) to see where the outside wheel edge will end up.
Old Oct 4, 2007 | 03:38 AM
  #30
Gdup35sedan's Avatar
ENVautoDetailing.com
even if they dont and you only need a little room to clear, you could get a 10mm spacer and still use the 225/40 tire since you have some negative camber with your drop.
-GP-
