Help I need Help
Old Oct 3, 2007 | 03:39 PM
FlyingLumpia's Avatar
Help I need Help
My buddy that is putting my brakes on, just called me and said I need about 20mm of space because the calipers are hitting the wheel. He suggest me to get a 20mm spacer on my car. Well I got a 20X8.5 Sevas with a 40 offset, there is no way that a 20mm offset will work on my car. Do you think if I get a 20 mm spacers with the stock 17 will work.
Old Oct 3, 2007 | 03:40 PM
redlude97's Avatar
whats the stock size again? 17x7+45? 17x7+25 should clear
Old Oct 3, 2007 | 03:44 PM
I think they are a 17X7 +45, He said the spokes are hitting on the 20's
Old Oct 3, 2007 | 03:55 PM
Jeff92se's Avatar
Red Card Crew
I'd try to find some oem Coupe 17s/18s or Z 17s/18s. All of those clear the oem brembos and "should" clear this too. There's a set of 17" Zs on Craigslist.
Old Oct 3, 2007 | 03:58 PM
MixturePinoy's Avatar
I'd let you borrow mine.. but my tires are staggered, and i'd need something to roll on
Old Oct 3, 2007 | 03:59 PM
He just texted me and said he put it all back to stock, so it looks like I either try again when I find some of those stocks or will be selling these to get something else.
Old Oct 3, 2007 | 04:01 PM
If I knew you needed the spacers I woulda gave you mine. i just gave them away to my buddy for his lexo... they were 20mm all around
Old Oct 3, 2007 | 04:06 PM
I really hope my buddy is just playing with me and suprises me when I get there, but really doubt that he would take it this far and long.
Old Oct 3, 2007 | 04:42 PM
G35Papa's Avatar
What Sevas do you have? You got the Wilwood BBKs right?
Old Oct 3, 2007 | 04:45 PM
I got the S22 and I got the kit with Wilwood calipers and brembo rotors. I am just wondering if I got the wrong brackets.
Old Oct 3, 2007 | 04:48 PM
Jeff92se's Avatar
Red Card Crew
If you got the wrong brackets, I doubt the rotors would fit properly.
Old Oct 3, 2007 | 05:11 PM
Never mind it wasnt the bracket. Its just the wheel spokes dont stick out enough to clear the caliper. I just talked to my buddy and he said a 15mm should be just perfect, but that would make my 20 to be a 25 offset and I still doubt that will fit my car.
Old Oct 3, 2007 | 05:21 PM
I think I read somewhere about someone grinding down thier calipers a few mm's and powdercoating them. That might be a last minute option?
Old Oct 3, 2007 | 05:24 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
a 20mm spacer on the stocker's will work easily. That would put you at an effective offset of +25... i'm running a +30 on a 9" wide wheel right now and it doesnt even come close to rubbing. as for the sevas, you MIGHT be able to get away with a 15mm spacer, depending on how low the car is, you will have a chance of rubbing the fender when turning up a driveway and all that good stuff. The paint on the inside of my fender is gone from rubbing the front when going up driveways when my car was slammed.
-GP-
Old Oct 3, 2007 | 05:30 PM
G SEDAN's Avatar
Grant, how did tim clear his RB BBK up front with the Sevas S-55? Do the S-55 spokes stick out that much more?
