OK- Ready to be ridiculed
I did the little clutch fix with plastic discs, etc. and I really like it. But here is the interesting thing. My mileage is now better. I always check what my mileage is by seeing how many miles I get with a fill up by setting the trip meter and dividing by the number of gallons I use. I usually get about 17-17.5 mpg over a whole tank, driving pretty much the same every week. Now I consistently get over 18. I am pretty sure this is a real difference. The only thing I can think of is that my shifting is more efficient and I don't overrev a little like I maybe did with each shift before with the awkward clutch position.
Doesnt seem to make any logical sense. There are a lot of factors that go into mileage that going from upper 17's to low 18's per gallon is such a small increase that I would say give it a few more weeks and keep monitoring the car. Where did you get the clutch fix plastic discs? I havent heard of that yet.
not to thread jack (it somewhat correlates) do you guys believe in the STP additives like the gas saver, or octane booster?
i recently added the octane booster (7bucks! ack!) to my full tank of gas, and it may just be in my head; but, i've felt a little bit more "pep" in the step even when not gassing it as much. You guys think it'll help w/ the gas problem too?
Originally Posted by Deepdiver
check out this thread https://g35driver.com/forums/showthread.php?t=168519
Originally Posted by ttrank
It could just be the weather cooling down.
Welcome.........NOOB!
Since you're a new guy I need to inform you that we don't ridicule! We have
another process we use called......
If you'll discover the thought
process called logic you won't ever catch the above mentioned process!
HAHA
If you'll discover the thought process called logic you won't ever catch the above mentioned process!
HAHA
HAHA
HAHA
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
