Hey G'dup35sedan, wheres the new bumper?
Originally Posted by OCG35
psedog - that mesh is perfect!!!! looks great!
Viet, do you have some of that mesh?
The custom auto mesh, mesh is plastic and has more of an OEM look to it.
Originally Posted by psedog
You don't want that mesh! Trust me. Get the Custom Auto Mesh stuff, it is much better. That mesh is metal and the paint for some reason started to turn white!?!?
)Anyway, I'm gonna use the Custom Auto Mesh - thanks for the heads-up
Originally Posted by FlyingLumpia
I was talking to a buddy and he mention that the drifters now are using rhino lining on the back of their bumpers to beef them up some. What do you guys think.
??? if so, what exactly does it do for the bumper?
Originally Posted by ttrank
The shop I spoke to said they are going to use a coating like that then sand it down smooth and paint/clear over it.
Is that what they do to stop rock chips? If so, then we all need that coating
Tim, is this what you are using it for? If it works I might consider it… I wonder how thick it ends up being?
I don’t think it will do any good for rock chips, since the paint and clear goes over it… however, since the bumper is fiberglass it might help with strength and keep it from cracking if it gets hit hard.
in a couple months time I had more rock chips in the fiber bumper than 1+ year with the OEM.
the fiberglass resin chips which brings the paint with it. The paint can't hold it together by itself.
... many of us plan to clear bra ours... do you think that would be enough? If not will the truck bed liner spray fix the issue?
What they were talking about was to help with rock chips. The outside gel coat on the fiberglass bumpers is very brittle and can crack with small rocks. With good prep, paint and flex clear you can avoid a lot but not everything. I'm going to try what they want to do and still make a clear bra for it too.
Truck bed liner stuff that is done by say Line-X is a multi stage process. There's the undercoating which is the bulk of the lining and than the texture coating. Both can be put on in varying degrees of thickness.
Test fit your bumpers before doing anything like this. Tolerances at points where it meets headlights, grille, fenders etc are tight for a reason.... so it fits.
Be prepared to sand and remold transitions it anything is laid on thick.
This is my worse case thought, no rebuttal is needed by anyone. I just want to say it fits before any kind of coating has been added.
I think I'm going to have a big protective steel box welded around my beautiful bumper
