DIY Video Series
#151
Originally Posted by kailep
Thanks for all the vids.
I just replaced my cabin filter w/ non-Nissan brand. It has an airflow direction arrow. On the OEM one, it doesn't have one.
Probably a dumb question but is the airflow going from top to bottom (blower)?
#152
Originally Posted by heftylefty58
Coincidentally, I just replaced my cabin filter with a Wix filter. Neither had directional arrows, but I remember seeing that the bottom of the filter was the dirty side--meaning the airflow went from bottom to top. Let's see what others say, though; my memory could be playing tricks on me.
#153
#154
Originally Posted by bythabay
My guess is that the airflow would be going from bottom to top, but that's just my guess; too lazy to check the FSM at the moment.
#155
Actually, now that I think about it, when you remove the old air filter, I think all the debris is on top of the filter, which would indicate the airflow is from top to bottom.
#158
#159
Originally Posted by Infinite_636
sweet, just watched the coolant video, very easy to understand and i think i'm capable of doing it myself. But, i liked the vids better when you were talking and instructing what to do. felt like someone was actually teaching me, i guess thats how i learn. this works too though.
#160
bythabay, I'm amazed at the wealth of Infiniti know-how you display every time I see a DIY vid uploaded. Without these DIY vids, I wouldn't be able to figure out how to do filter changes, belts, install plenum spacer, etc. I know I can't speak for everyone here on this forum, but I think it's safe to say we all fully appreciate the contributions you have given on Driver (and much more)
Just curious (and not to stray too off-topic), but how do you know so much about fixing up and maintaining our cars? You used to be a master Nissan/Infiniti service tech, or did you learn by yourself and pick up from there?
#161
#163
#164
Originally Posted by Infinite1
Quick questions...I'm about to perform a rear break job on my coupe. How did you end up taking the rotor off? How many clicks up did you go? When placing the rotor back I noticed you backed off the clicks does it matter quite a bit? Thanks for the advice and thanks for the vids!
We took the rotor off by loosening the parking brake cable (I clicked it all the way to the end and only then did the rotor come off).
When you put the rotor back on, click 'till you can feel the parking brake engaged, then back off about 5 clicks.
#165
