Height/Legroom Problem!! 6ft7 275lbs, Can I extend seat??
Old Nov 16, 2007 | 02:21 AM
Kazaam's Avatar
Unhappy Height/Legroom Problem!! 6ft7 275lbs, Can I extend seat??
Just like the title says, I'm 6ft7 275lbs lean and long. I got an 05 X sedan that I fit OK in but I was wondering if this has ever been done by anyone on this forum. I fit fine but when I lean far forward I can scrape my head on the sunshade lol. I never almost never have anyone ride behind me either. Is it possible to extend the seat back without having to do it permanently?? Good thing this isn't my daily driver, but sometimes I feel like I'm driving a Prius LOL help with any ideas, suggestions....
Old Nov 16, 2007 | 02:41 AM
Joe_Camel's Avatar
Jeezus man, I'm only 6'2 220 and *nobody* sits behind me, it is expressly forbidden! I suggest you drive barefoot & remove the padding from the driver seat, or get a good blowtorch & buy some extra seat rails from a junk yard so you can slide the seat farther back (there's a good 5 or 6 inches there before you hit the back seat).
Old Nov 16, 2007 | 02:45 AM
Kazaam's Avatar
Is it possible to get it done if I am actually able to buy an extra set of rails?? I could use all 5 or 6 inches LOL??
Old Nov 16, 2007 | 02:53 AM
j 4 lD's Avatar
No you cannot do this. I recommend that you raise a bump in the roof just where your head is. A local body shop can do this for you for under $200 simply by cutting a 12 inch hole above your head and inserting a glass dome. Or you can rip out the ground and go Flintstones style. let me know how it goes either way.
Old Nov 16, 2007 | 02:57 AM
Kazaam's Avatar
freaking idiot. Go get stupid elsewhere please, I'm asking for some serious suggestions.
Old Nov 16, 2007 | 03:14 AM
j 4 lD's Avatar
Old Nov 16, 2007 | 03:58 AM
hyukki's Avatar
Old Nov 16, 2007 | 03:59 AM
Kazaam's Avatar
lol damn, you grown folks got nothin better to do than jack up my thread???
Old Nov 16, 2007 | 04:20 AM
iiiiiekoiiiii's Avatar
Dont worry bro Ur not the only One. Im 6ft 220lbs solid. My seats feel tiny lol. Comin from a chrysler 300m I was comfortable as my bed.
But im thinking about swapping to 07 Seats. i set in them and love the way it holds. MUUUUCH more comfortable then my tiny seat. i gotta 06x
Old Nov 16, 2007 | 09:17 AM
Philly_G35's Avatar
I'm sure a good fabrication shop should be able to extend or move your sliders. I would imagine it would be on a more permanent level though. If those tools on Unique Whips can figure it out, there has to be somebody in your area that can. I am about 6'-3" and I have plenty of headroom. My seat is adjusted all of they way down with a little recline in the seat. My 5'-7" Dad had my car once and when I got back in I couldn't sit without my head hitting the roof.
Old Nov 16, 2007 | 10:40 AM
GeeWillikers's Avatar
Walking The Fine Line...
+1...
Old Nov 16, 2007 | 11:18 AM
DaveB's Avatar
Do a search for a seat mod. I know there is a bolt under the seat that you can adjust to free up some more space.
Old Nov 16, 2007 | 11:20 AM
03Sg35's Avatar
Well, im 6' 4" 245lbs I had some issues, but I read somewhere you can ajust the stops on the height rail, they are little plastic stops that when ajusted you can move the seat lower giving you some .75"-1" more head room. also if you can find some coupe seats those seats bolt in to sedans and you gain 1"-1.5" head room. As far as the sliding back I have no idea
Old Nov 16, 2007 | 11:31 AM
sethlamb's Avatar
go get an escalade...and pimp it....lol
Old Nov 16, 2007 | 12:06 PM
4 Door Skyline's Avatar
dude....u should be in the NBA....or in the NFL god knows the Dolphins need a TE
Anyways, even I have problems and im only 5'11'' and i dunno if its the way my body is or something but i got maybe a finger between the top of my head and the roof, ive even found myself hitting the roof on serious bumps (dont ask, they were not seen).
And as far as I know the only thing I could think of is to get some new rails fabbed up....Im sure there are plenty of shops in ur area that deal with custom fabrication....its all a matter of research man, start callin around all the shops and im sure 1 will point u in the right direction.
Good luck
