SET light flashed and now Cruise control not working
Old Nov 20, 2007 | 01:38 PM
ra45tp's Avatar
I called the dealer and asked if there was anything I could check before bringing it in. They said there is a laser somewhere in the front bumper area that measures road speed and to see if it was dirty. Anyone have experience with this and if so do you know where the laser is located. My search revealed some cruise issues when the ECU gets damp but that is not the case for me.
Thanks
Old Nov 21, 2007 | 12:07 AM
ra45tp's Avatar
Found the problem - clutch pedal not returning all the way
I noticed on the drive home that the clutch pedal seemed low a few times and I could pull it up with my foot. When I did this the cruise worked fine. I adjusted the clevis out a couple of turns and everything works fine except now I'm back to the incredibly long clutch throw.
Old Feb 25, 2008 | 09:03 PM
FenixL1P's Avatar
laser to measure road speed??? that's total bs....
Old Feb 26, 2008 | 09:51 PM
QuadCam's Avatar
not on the G. Infiniti has laser controlled cruise control, but not on the G.
BTW, I have had this flashing "set" on my cruise control. it has happened twice and I have no idea why it happened or why it started working again.
Old Feb 27, 2008 | 10:01 AM
ttrank's Avatar
Grocery getter
I have also had this problem twice. Both times it was in the heavy rain and went away on a power cycle.
Old Mar 9, 2008 | 05:06 AM
Strtsk8r321's Avatar
This happened to me tonight so I pulled over and turned the car off and turned it back on and the problem was still there. Anyone know how to fix it?
arora_g35
Apr 16, 2026 02:52 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
ghost_g35
Aug 7, 2015 10:31 AM
Jadenkid22
Jul 14, 2015 12:33 AM
