Stillen Gen 2 on G35 sedan At
Old Nov 25, 2007 | 10:19 AM
jimmykce1's Avatar
Can someone post a sound clip of this exhaust on an automatic sedan cruising at 2 and 3 rpms. I would like to hear how much droning there is on this exhaust from inside the car.
Old Nov 25, 2007 | 10:34 AM
crislbcG35's Avatar
Found this on YouTube.
Old Nov 25, 2007 | 01:48 PM
OCG35's Avatar
it's quite tame actually. I don't have sound clip but have heard it... it is much less audible than gen 1... at idle and low rpm it's not much different than stock.
Old Nov 25, 2007 | 02:33 PM
04G35NYC's Avatar
Gen 2 FTW!!!
Old Nov 25, 2007 | 03:27 PM
jimmykce1's Avatar
Originally Posted by crislbcG35
I seen that one.
Old Nov 26, 2007 | 12:38 PM
jimmykce1's Avatar
bump..for sound clip
Old Nov 26, 2007 | 01:05 PM
Graphite05G's Avatar
The RV Specialist
I have to many mods to get an "honest" sound of the exhaust, I will tell you N/A with the stock cats was fairly quiet at all put wide open above 4K. I tried test pipes...WTF that thing is loud! I now have the Kinetix cats, and still louder than I would like but not that bad, get a lot of compliments on the sound. If nobody does a clip I will work on getting one.
Old Nov 27, 2007 | 01:01 PM
The RV Specialist
AS Promissed---again its a little off because of the other mods, but here are a few I made this morning...
Old Nov 27, 2007 | 04:51 PM
Konsole's Avatar
http://www.youtube.com/watch?v=b9lE8N2bv0I
http://www.youtube.com/watch?v=hgC9_npHeF4
http://www.youtube.com/watch?v=0E8NXrEXbmY
Thank you for the effort, but the mic on whatever you were using doesnt pick up ANY of the lower frequencies. That is not a good example of the sound at all.
I am going to get a high quality mic and try to record a sound clip.
Old Nov 27, 2007 | 04:56 PM
Jeff92se's Avatar
Red Card Crew
Can you post pics of the Gen II version? Or describe how it's diff than the Gen I?? Stillen doesnt' have pics of the Gen II
Old Nov 27, 2007 | 05:29 PM
Konsole's Avatar
ok, here is an mp3.
This is Stillen Gen2 exhaust on my car.. .i have a pop charger but i dont think it changes the sound of the exhaust.
NOTE: The exhaust sounds lower frequency when cruising around in gear. This is in Neutral. It sounds better when driving in gear.
I think I will get my other plastic computer mic and tape it to the bumper with a computer in the trunk to record driving around.
In this clip... i start, let idle for a second (its cold out) then I smoothly rev to about 4k.. then i rev a couple times fast, push -- push... and then idle again.
My idle in this clip is above 1k rpm still... in gear and warm it is lower and more gurgley
http://konsole.net/pictures/g/stillen_gen2_ingarage.mp3
Old Nov 27, 2007 | 05:31 PM
Konsole's Avatar
pics:
Old Nov 27, 2007 | 05:35 PM
Jeff92se's Avatar
Red Card Crew
Thanks! I wonder what's diff? It all looks the same. New muffler maybe?
Old Nov 27, 2007 | 08:25 PM
OCG35's Avatar
if they told ya they'd hafta kill ya...
Old Nov 27, 2007 | 08:30 PM
The RV Specialist
The only thing that I have noticed is the muffler on the gen 2 has dual in dual out but in the muffler itself uses a single passage thought the center. Someone needs to see if the Gen 1 has a dual passage muffler. Maybe?
