Puddle Lights (rice or not)
Old Nov 26, 2007 | 05:07 PM
Ku-Ling's Avatar
That's borderline rice. I can see where you are going with it, but at the same time I get this nagging question..."Why?"
It seems more to show off than be functional...which is okay in some circumstances, but I'm just not feeling it.
And I think you're asking too cause you're on the fence. Ultimately your call though...good luck!
Old Nov 26, 2007 | 08:23 PM
Crespo's Avatar
Those are nice. Those are one of those lights on every merc barbus car.
Old Nov 26, 2007 | 09:37 PM
clinthammer's Avatar
yup these were copied of the Brabus puddle lights
Old Nov 27, 2007 | 12:33 AM
marty315's Avatar
Led's in the under door lights FTW. Look sharp, look distinct, light up the ground and cost a hell of a lot less.
Old Nov 27, 2007 | 12:54 AM
Calvin's Avatar
Overglorified Altima
It's been done...to a coupe.
Don't get them or not get them because others like/dislike it.
Old Nov 27, 2007 | 01:11 AM
psedog's Avatar
Back in SD**
Rice or not I like them. Those on the coupe look pretty good, to me.
Old Nov 27, 2007 | 01:26 AM
Yes those look good but I want the ones with more focused output like this:
Old Nov 27, 2007 | 02:18 AM
psedog's Avatar
Back in SD**
From a functionality standpoint, I don't see why. I would think the ones on the coupe would light up a puddle much better than the ones on the xB
Old Nov 27, 2007 | 02:49 AM
Beebo's Avatar
i now iv seen a black sedan with them in the gallery... they looked ok to me
Old Nov 27, 2007 | 04:20 AM
i will try to get a local shop here to give me a test fitment. Regarding wiring, saw this:
https://g35driver.com/forums/showthr...ight=tap+wires
The puddle lights have two wires and I assume they have to tap into the panel like the above pic. Would it be safe since they puddle lights are 12v?
Old Nov 27, 2007 | 12:06 PM
sliderg35's Avatar
I think they look good. You can't just plug them into any 12V source, they would need to be plugged into the cabin lighting circuit so they only come on when the cabin lights are on. You should only need one wire from the harness and the other goes to ground.
Old Nov 27, 2007 | 12:08 PM
g35man04's Avatar
CLUB MODERATOR
yea thats the way i am going to wire mine....but i need to get some mounting brackets first.....
Old Nov 27, 2007 | 12:10 PM
drilling skirts maybe
http://www.scionlife.com/forums/viewtopic.php?t=122266
Old Nov 27, 2007 | 12:18 PM
g35man04's Avatar
CLUB MODERATOR
not sure im going that route..there are brackets you can get to install with them....I think i may take that route...I am going to order the CCFL tubes to install on the interior!
Old Nov 27, 2007 | 12:48 PM
  #30
for me the only issue with brackets is the puddle light will be outside so prone to getting hit if there is road debris. If they are drilled and sunken into the side skirt, only the light lens is prone to damage.
