Brake shutter
Old Nov 27, 2007 | 04:46 PM
Xer's Avatar
Xer
Brake shutter
Guys, I have noticed some brake shutter at mid to high speeds, but not at lower speeds. Any ideas. I have not brought it to the dealer yet, the car past inspection last week so I assume the pads are decent, they look good on a visual inspection.
Old Nov 27, 2007 | 05:17 PM
dualGz's Avatar
Sounds like warped rotors. I get the same thing from about 60mph and above. Mostly my fault though. Racing the car to break in the brakes... Lol. Oops.
I'm gonna pick up some new rotors this week. It's starting to annoy me. Lol.
Old Nov 27, 2007 | 05:24 PM
cimabeu's Avatar
First symptom or warped rotors. If they didn't test drive it on inspection, they would have missed it. Good luck- can get expensive and even tricky trying to pick the "perfect" rotor.
Old Nov 28, 2007 | 09:37 PM
blutaco's Avatar
I have had the factory rotors changed twice already, pretty much every 35000 miles they start warping (done under warranty). I have a 2003. Next time I will just install some aftermarkets.
Old Nov 29, 2007 | 09:41 AM
myG35ZX's Avatar
The rotors do seem to warp easily. I keep extra's in the garage. In fact, when I change the compression rods this weekend I was planning to change them again as I have the "shakes".
Old Nov 29, 2007 | 12:53 PM
CLyons0203's Avatar
most of the time the rotors arent warped. The shakes are usually caused by material from the pads sticking to the rotors, making the rotor surface uneven. Wash your brakes and see if they still shake. By wash I mean clean the rotor surface with brake cleaner or degreaser. Dont get this stuff on the body of your car or the rims!!
Old Nov 29, 2007 | 01:40 PM
myG35ZX's Avatar
I'll give it try. Thanks.
Old Nov 29, 2007 | 02:22 PM
obsdnoblivion's Avatar
So nobody would resurface their rotors? If not, why?
Old Nov 29, 2007 | 02:23 PM
Texasscout's Avatar
Read THIS first!!!!!!
Old Nov 29, 2007 | 02:59 PM
Good read. But resurfacing the rotor still seems to be the way to go with the vibration to me. If there are deposits of material from the pad to the rotor, what better way to get it off evenly that by actually setting everything to zero by flattening everything? That would seem far more exact than "garnet paper." What is that anyway?
Old Nov 29, 2007 | 03:06 PM
myG35ZX's Avatar
I never resurface (never have). I would rather replace. Removing material just never made sense to me.
Old Nov 29, 2007 | 03:17 PM
Texasscout's Avatar
You're not wrong here. I have had several mechanics tell me that the rotors are so thin now anyway, there is nothing left to machine. By the time you get all the grooves out, you are beyond the minimum thickness.
Old Nov 29, 2007 | 03:18 PM
Texasscout's Avatar
It's the "brown" sand paper. What would it hurt to use a palm sander and break the glaze first? If it works, you're money ahead.
Old Nov 29, 2007 | 03:36 PM
Good point. I reckon I'll try to find this stuff. Should I look for it at Auto Zone or Home Depot?
Old Nov 29, 2007 | 04:24 PM
Texasscout's Avatar
You can find it both places. Look in the "body work" section in AZ.
