Finally made the decision on rims!! Seva 3 stars!!
Old Dec 1, 2007 | 08:31 PM
EM3RGY's Avatar
my fx has 20's and each tire was 128, then about 70 or so on shipping for all of them!
Old Dec 1, 2007 | 08:33 PM
g35freak86's Avatar
wow. that is a good deal!! I'll most likely use this site to get the tires. Thanks man!
Old Dec 1, 2007 | 09:24 PM
perry05G35's Avatar
you could go with a 245/40/19 tire on all 4 wheels it will fill more of the wheel well and give you a better ride plus if you decide to lower your car you will not rub. I highly recommend it if it's affordable for you.
Old Dec 1, 2007 | 09:31 PM
g35freak86's Avatar
a 245/40/19 would fit on a +35 offset rim? I don't plan on lowering it anytime soon but in the future I was thinking about it. So you suggest a 40 offset on the rims and tires over a 35? How come?
Old Dec 1, 2007 | 10:09 PM
FlyingLumpia's Avatar
What they are saying is get the 19x8.5 with the +35 offset. For tires get 245/40/19, it will be a better ride and since you are not lowering it, it will cover up some of the gap. I agree also +35 offset.
Old Dec 1, 2007 | 10:14 PM
O HELLA OEM's Avatar
there nice
Old Dec 1, 2007 | 10:24 PM
GEE35FX's Avatar
I would listen to Chico's recommendation "20x8.5 +35 with 245/35/20 all around" Those wheels should look great.
Old Dec 1, 2007 | 10:48 PM
They dont make them in 20's
Old Dec 2, 2007 | 12:01 AM
g35freak86's Avatar
OOhhhh ok I get it. get +35 rims but +40 tires. makes sense now lol. What if I do decide to lower it in the future if I have that setup? Do you think it would rub? Most likely I won't lower it but just incase
Old Dec 2, 2007 | 12:57 AM
EM3RGY's Avatar
I think you should lower it at least a little. maybe tein h-techs? your car will sit really high on those new wheels, so a little drop would look good IMO.
Old Dec 2, 2007 | 01:23 AM
clinthammer's Avatar
Guys - I have the Works in 19 x 8.5 +42 offset but its now at +37offset (running 5mm spacer) and I had to change out my stock wheel bolts. If he gets the +35 wont he have to change out the bolts?
Old Dec 2, 2007 | 01:27 AM
g35freak86's Avatar
https://g35driver.com/forums/wheels-tires/173113-another-broken-sevas-wheel-eek.html yikes. starting to think 2nds onn the sevas. don't want this happening!
if I lowered my g on tein h-techs springs. would I have issues using the stock shocks on there? How much would it lower it. any pictures?
Old Dec 2, 2007 | 01:29 AM
G SEDAN's Avatar
no sir, the only reason you changed yours out was because of you running spacers. It shortened the threads on the studs for the lugs. The wheels made at a certian offset doesn't compromise the threads. I'm so tired so this explaination might not make sense. I'll explain tomorrow if it doesnt lol
Old Dec 2, 2007 | 01:30 AM
actually it does make sense - thanks for clearing it up
Old Dec 2, 2007 | 02:05 AM
  #30
g35freak86's Avatar
what do you think of ADR or Stern rims? or should I just stick with the Sevas? I just want a nice safe wheel that I won't have to worry about
Edit: I don't think i'm going to drop it because I don't have enough money if I run into camber issues. I'll just stick with the +35 rim and a +40 tire to fill in some of the wheel well gap
