Spoiler install...help requested
Old Feb 18, 2003 | 11:31 PM
chinee's Avatar
Hi all,
Need some help/advice from those who've done this before...
Received my aftermarket spoiler from infinitiparts.net, beautiful piece, but....although I'm pretty handy, I do not want to take the chance of damaging my G in anyway at all. There were no instructions included.
On the attached pic, I received:
2 foam pads, (1)
5 cardboard strips with holes surrounded by adhesive (2)
2 clips, to join wires I believe (3)
4 allen head screws (4)
2 black plactic caps (5)
and not shown, the spoiler and 2 templates.
Here are a few of my assumptions:
- I drill 5 holes in the trunklid, 4 screws, 1 wire pass through. At point B, it appears a simple drill through (a flat part of the trunk) then secure screw to spolier.
- However at point A, it appears that I have to drill through the trunklid, then from the other side (inside), drill an additional hole through the hollow part of the trunk support structure for access.
A few questions:
- For the electrical, point C, do I snip off the connector and use the clips provided to splice this wire to the spoiler's wire?
- Does the adhesive side of the foam pads attach to the underside of the spoiler?
- Should I use some sort of sealer to protect against water and rust around the holes I drill? Silicone, grease, ...?
- What size drill bit do I use for the holes in the trunklid?
- What size drill bit do I use for the access hole on the inside of the trunk, assuming that I assumed correctly above?
- Am I forgeting anything?
- Am I missing any parts?
I've already identified the connector for the third brake light for disconnection.
Any help will be appreciated....thanks.
'03 Infiniti G35
'02 Toyota Sequoia
Old Feb 18, 2003 | 11:34 PM
chinee's Avatar
Re: Spoiler install...help requested
Also, what are the 5 cardboard strips for? Do I use these as markers for the holes prior to drilling?
'03 Infiniti G35
'02 Toyota Sequoia
Old Feb 19, 2003 | 05:22 PM
chinee's Avatar
Hey, thanks a lot Dave!
I'm excited, but nervous as hell. I'll do the install this weekend.
The cardboard strips... what are they for? Did you disregard these and use the masking tape instead?
Thanks again!
'03 Infiniti G35
'02 Toyota Sequoia
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
dseet
Oct 11, 2015 12:40 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
JKL1031
Sep 11, 2015 07:58 PM
