Shifting Problem
Old Mar 1, 2004 | 09:16 PM
Twylight's Avatar
Shifting Problem
Hi all,
I'm having a wierd "problem". I have a '04 Sedan AT and when I use manualomatic mode I "grind" gears when I do a high rpm shift up to second - it happens about 50 percent of the time - its like 2 grinding noises then it takes - doesnt seem to matter if VDC is on or off.
Can your automatic transfer from 1-2 in high rpms? like near 6500?
If so any idea what I should bitch at my dealer to look at?
Thanks
Worth
2004 AT DG/Sport/Flaps/Premium/max tint/Bose/CAI Injen/6 wire ground kit/Custom ECU
next mod: Zaino baby
Old Mar 3, 2004 | 12:20 PM
bobfinley08's Avatar
Re: Shifting Problem
All shifting problems went by-by with a 7lead grounding kit.
Ask my hero DaveO. He knows ALL!! Also,check the grounding
wire threads ( 7th wire )
Good Luck,
old road rat
Old Mar 4, 2004 | 10:41 AM
mrman_3k's Avatar
Remember, with grounding wires, not only does it fix any shifting problems, it will also make your engine smoother, and for every wire it adds 4rwhp. I also hear it can help your mind believe whatever you want.
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
cmesidewayz
Sep 29, 2015 09:28 PM
Jnm07
Sep 5, 2015 01:16 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
kevintandmd
Sep 3, 2015 06:41 PM
