Headlight work - Matte black and cleared
Old Dec 18, 2007 | 11:59 AM
  #31
Sacch's Avatar
These headlights looks awesome!!
Old Dec 18, 2007 | 12:00 PM
  #32
ashish's Avatar
looks great man.
Old Dec 18, 2007 | 12:09 PM
  #33
AthensBlueG's Avatar
Brian
Oooh. That looks really nice. Looks professionally painted too! It definitely goes well on an IP
Old Dec 18, 2007 | 12:35 PM
  #34
ttrank's Avatar
Grocery getter
Originally Posted by GeeDM
Just had a question..when you pop off the lenses...is there anyway to make them look new again...i mean...remove the pits from rocks and such before putting them back on???? Also, anyone know if there is a "DIY" on this with what grit sandpaper to use and what not???? i think i'm going to do this this weekend..
I would not sand them down as it can make them foggy. If you do, use a very high gritt and then polish them.
Old Dec 18, 2007 | 02:12 PM
  #35
G35Papa's Avatar
Originally Posted by g35freak86
yeah if I end up doing it, I would add some silicone around it just to be safe like Tim said.
What kind of paint should be used?
I used flat black sandable primer. (Duplicolor). After removing the bezels, we sanded them down with 400 grit sandpaper for about 45 (or more) minutes, removing all the chrome/shine. On the slotted sections, we made sure to go with the lines. Put on two thin coats of the primer and sanded down any imperfections. Put on another coat. At this point, it looked so good, we stopped there and just started applying more thin coats. After the initial 2, we added another 5 more thin coats and it was done. If you plan to go with a semi-gloss or gloss paint, I recommend doing our initial plan....after the 400 sand of the primer, add one more coat of primer and then start sanding that base with 600, then 1000 then, 1500 then finally with 2000. You may be able to get away with less sanding if your bezels are nice and smooth like mine came out.
He used a piece of florescent light
Yep. I bought an actual cover for a fixture vs. a flat insert piece (~$13 for the cover). The cover was twice as thick as the panel sheets you can buy.
Originally Posted by Socal_G_sedan
looks clean..any plans for retrofit in the future since you alread broke it open once you'll know how to do it again!
The original plan called for a projector retro-fit to replace the turn signal lenses. The projector was literally 1 to 2 mm too big! So, we scrapped it and went for the clear lense. I'm already planning for a projector retro-fit once I find some that will work I have another set of bezels to play with and pefect for when that day comes
If you want to do work on the lenses, I would do them on the car so they are stable and secure. I winded up ordering new headlights from ebay (none OEM) so I swapped out the old lense for the new. I did the sand and polish to my OEM set...didnt work out for me. PM me and I can give you the details on what to do if you want to give it a try
Originally Posted by mixturepinoy
Very nice, what grit did you use to sand down the part with the lines? I'm having trouble right now because that area wont hold paint..
You're using primer first right? then the paint? Use a cardboard piece or old credit card and wrap the sandpaper around that. Remember, you just want to sand it down to get the smooth/shiny surface roughed up and not enough to sand it down. See my first response to g35freak for the process.
Thanks everyone for your comments/compliments. DIY always has a great feeling of accomplishment, even when you don't do all the work yourself.
Feel free to post up more questions here or send me a PM.
Old Dec 18, 2007 | 02:20 PM
  #36
Truth's Avatar
Very Nice! How much do you charge?
Old Dec 18, 2007 | 02:25 PM
  #37
G35Papa's Avatar
lol
$1000 per light
If you're local, some good pizza and beer
EDIT: You are local...make that a years supply of pizza (and light beer)
Old Dec 18, 2007 | 02:36 PM
  #38
ttrank's Avatar
Grocery getter
You don't need to sand that far.
You can prime and sand with 400 then use a sealer primer and paint. Then wetsand with ~600-800 and clear. If you have nasty orange peal or overspray, you can wetsand the clear with ~1200.
Old Dec 18, 2007 | 05:32 PM
  #39
G35Papa's Avatar
^That's experience talk right there Thanks ttrank
Old Dec 18, 2007 | 05:43 PM
  #40
MixturePinoy's Avatar
hmmm... i think that may be my problem.. i just sanded and painted it...i think i gotta do it over again.. arghh
Old Dec 18, 2007 | 06:16 PM
  #41
G35Papa's Avatar
Primer is your friend. The base is the most important part.
Sand it back down using 400. Primer it with two THIN coats (about 10 minutes in between each coat), then sand it again with 400 to get rid of any imperfections. One more coat of primer. See how that looks and if it needs more sanding and primer.
Are you doing a black flat finish? or gloss? See ttranks notes above too
Old Dec 18, 2007 | 06:18 PM
  #42
I used flat black duplicolor. I don't think I want to put clear on though, i like the super flat look
Old Dec 18, 2007 | 06:47 PM
  #43
G35Papa's Avatar
Make sure you use a BLACK primer for the base (NOT grey) as the black will wind up looking like like a real dark grey instead of black if you go with the grey primer.
The black primer might even be dark enough for you. We not only used it on my headlights but we did it on a set of 06 coupe headlights as well. Thin coats...
Old Dec 18, 2007 | 07:34 PM
  #44
GeeDM's Avatar
What type of silicon do you use to re-seal the lights(if you had to)...i'm seriously doing this this weekend...
Old Dec 18, 2007 | 07:52 PM
  #45
G35Papa's Avatar
No sealer was used. Once we were done we put them back together, threw it back in to bake (14 minutes at 215). Pulled them out and pushed/seated them back together. Its been raining here for the last two days (especially today). I'm going home now to re-check for condensation.
This process has been used in the past (no-sealer applied) and has worked so far so I don't think I will have any issues as well. (fingers crossed ).
