Headlight work - Matte black and cleared
Old Dec 18, 2007 | 01:43 AM
G35Papa's Avatar
Did some work on a set of headlights yesterday with a few people up here in Norcal. Very pleased with how they came out. I needed new lenses badly
On to the pics
I'll take some better pics during the day later on this week and post them up.
Old Dec 18, 2007 | 01:51 AM
g35freak86's Avatar
wow. Chris. that looks Unreal. I want this done to mine so bad! How much did this run you if you don't mind.
Old Dec 18, 2007 | 01:56 AM
ttrank's Avatar
Grocery getter
Those look great! Very clean.
How did you do the blinker? It looks like it is on the outside.
Old Dec 18, 2007 | 02:00 AM
G35Papa's Avatar
^Thanks Chris. It was free
I did it with another friend (member on the board) of mine yesterday. Actually, a few of us touched these lights at one point or another. Took us all day as we ran into a few snags but we worked through them and you see the results above.
1 pack of sandpaper and two cans of black primer and a few hours of sanding, painting baking and putting them back together.
Old Dec 18, 2007 | 02:02 AM
g35freak86's Avatar
wow. I would definatly pay you to do this lol. it looks great
I could take this on myself but just the whole headlight removal and baking of the headlights is the only thing that doesn't settle well in my stomach lol
Old Dec 18, 2007 | 02:04 AM
G35Papa's Avatar
Thanks Tim
The blinker is on the inside covering up the original spot were the orange ring/cover was before. I used a dremel and cut out a piece of florescent light cover, sanded it down with the dremel then polished/sanded it with 400 grit wet/dry paper. Glueing the piece in was nerve racking. I almost opted not to clear them cause I was afraid to F up. Glad I was persuaded to go for it
Old Dec 18, 2007 | 02:05 AM
ttrank's Avatar
Grocery getter
It's not that bad at all. I have had mine open 6 times and plan to do it again soon to change the lenses in my TL projectors again.
Old Dec 18, 2007 | 02:06 AM
g35freak86's Avatar
really? how long do you put it in for and what temperature? Also, how to do reseal the lenses back on, in other words, what do you use to reseal it?
ttrank's Avatar
Grocery getter
Originally Posted by G35papa
Thanks Tim
Very nice work!
Those blinkers are a PITA and you did a great job.
Old Dec 18, 2007 | 02:07 AM
geesteezd's Avatar
that looks AWESOME.
would look great on an OB
ttrank's Avatar
Grocery getter
I always do ~12-15 min at 185 and they open right up. Same to heat the glue to reseal.
What did you use Papa?
Old Dec 18, 2007 | 02:08 AM
G35Papa's Avatar
The removal of the headlights is not big deal (at least for me it wasn't).
After doing this mod with someone who has done it before and helping along the entire way, it isnt as bad as I thought it would be. I would have no problem at all taking on this mod again in the future and will probably do another set at some point (adding some projectors or color matching the bezels to the body color). It is time consuming because you really need to just take your time.
JOKER's Avatar
CLUB MODERATOR
looks pretty nice
Old Dec 18, 2007 | 02:11 AM
G35Papa's Avatar
Pre-heat the oven to 215, put the lights in for 14 minutes, remove and the pop them open.
Heres the kicker, no sealant was used. We re-used the same OEM sealer that was on the lights. Works like a charm
Old Dec 18, 2007 | 02:12 AM
g35freak86's Avatar
so in order to reseal it. you just put the headlight back into the oven at 215 for 14 minutes and the glue heats upa nd you stick the lens back on?
