Which 20" rims should i get for my 05 X?
Old Mar 1, 2008 | 02:08 PM
spiderrider_23's Avatar
I am stuck between 2 different rim and need help on what will look beter for the more classy look and shine in the summer sun?
1.) Foose Speedstar 6
http://www.thewheelconnection.com/ph...&brandsearch=1
2.)Moz Centerfolds
http://www.autowerxinc.com/pop.php?products_id=3771
i need help or if you have any other suggestions... i am looking for 20" chrome deep dish or even if there are some with white chrome on it... i am open for suggestions and links...
thank you
Old Mar 1, 2008 | 02:17 PM
KrazyEd's Avatar
IMO, both of those are hideous. Im not a chrome hater by far but its the style of the wheels that just does not do it for me...But everyone has there own taste so if it was between those 2 I would go with the Moz Centerfolds.
Old Mar 1, 2008 | 02:49 PM
ILLicit's Avatar
HOOD RIMS y0
Old Mar 1, 2008 | 03:23 PM
FlyingLumpia's Avatar
What is your budget. I am sure you can get some better wheels than that.
Old Mar 1, 2008 | 03:26 PM
geesteezd's Avatar
Baaaaaalin'
Old Mar 1, 2008 | 06:22 PM
jonE5's Avatar
i realize that the X is the slowest G out there, but why would you want to make it even slower with 20" wheels?
stick w the 19"
jon!
Old Mar 1, 2008 | 06:58 PM
FutureGDriver's Avatar
stick w the 19"
jon!
where u get dat from u mean slower than the G37'S
Old Mar 1, 2008 | 07:46 PM
jaydafunk's Avatar
i would choose #2
Old Mar 1, 2008 | 09:32 PM
w0ady's Avatar
fgc moderator
#2.
Old Mar 1, 2008 | 10:27 PM
oyeeAH forgot u wanted our imput on da rims
#2 is balllin
Old Mar 1, 2008 | 10:57 PM
Kazaam's Avatar
#2, don't listen to some of these idiots that don't know how to answer a simple question.
Old Mar 1, 2008 | 11:01 PM
B L U E S L A T E's Avatar
Honda Accord
I like that multi spoke design of the the #2...
Old Mar 1, 2008 | 11:11 PM
perry05G35's Avatar
On a serious note neither set will fit your car. People may not like the design you chose but nobody has addressed the most important factor which is will they fit? The smallest size that both designs offer are 20X9 and 20x10. Since you have awd it's important to maintain the same wheel width for all 4 wheels. The largest you can fit in front is 20X8.5 so to maintain the same size on all 4 wheels the largest you should go is 20X8.5. If you want to pull your AWD fuse then you can go staggard and go with a 20x10 in the rear but you'll still run into a problem trying to fit a 20x9 or 20x10 in the front you can cross out the 20X10 the 20x9 is doable but you will have to run some negative camber and around a +30 to +25 offset to get them to work in the front and a smaller tire which would expose your rim to curbs yikes just pass on these two....
Old Mar 1, 2008 | 11:25 PM
perry05G35's Avatar
Here's some suggestions that are simular to what you are looking for and in the 1500 to 2000 price range....
http://cgi.ebay.com/ebaymotors/NEW-2...3756.m20.l1116
Old Mar 1, 2008 | 11:34 PM
Jedunnigan's Avatar
Originally Posted by perry05G35
On a serious note neither set will fit your car. People may not like the design you chose but nobody has addressed the most important factor which is will they fit? The smallest size that both designs offer are 20X9 and 20x10. Since you have awd it's important to maintain the same wheel width for all 4 wheels. The largest you can fit in front is 20X8.5 so to maintain the same size on all 4 wheels the largest you should go is 20X8.5. If you want to pull your AWD fuse then you can go staggard and go with a 20x10 in the rear but that would defeat the purpose of having AWD...
The 2nd comes in 20*8.5...
