Good jack to change tires?
I know the OEM jack is really weak! so what type of jacks are you folks using to change flat tires? Could i use a regular hydrolic jack, or are our cars too low for that? Are there any good scissors jack you can recommend?
This is only for changing 1 tire, so i'm not looking for jack stands/ramps/ect. thanks for the help.
Re: Good jack to change tires?
The stock jacks could do the job if you're just putting on a spare. Do make sure you are on a flat surface when using it. You could also pick up a small hydraulic jack if you want to keep costs down........that is if you're planning on keeping one in your car. Otherwise, it would be very convenient to have 3-4 ton hydraulic jack.......running about $100.
Certified Window Tint & Detailing Specialist
Clearshield ("Clearbra") Authorized Dealer
Madico Dealer
syu@machiii.net
Madico Dealer
syu@machiii.net
b2autodesigns
Accessories-Vendor
70
Feb 25, 2017 01:12 PM
