Floor Jack Pad/Adapter
Old Jul 24, 2015 | 12:26 PM
DRG35R's Avatar
20 Year Member
G35 Coupe "Sport Package"
anyone looking for a great adapter for their floor jack please be sure to check out the following link.
https://www.zl1addons.com/index.php/...ackpads-detail
ordered this adapter for my floor jack on the advice of John at ZL1addons and it works great.
just find a spot along the pinch weld near the factory jacking points. adapter will stay attached as it is magnetic. slide jack under adapter on car and off you go with no worries.
used mine for the first time today while changing my wheels and it could not have been easier or safer. first time I really felt comfortable jacking car with the floor jack with no worries of damage or slipping.
great product and highly recommended if you use floor jack.
Old Jul 27, 2015 | 10:28 PM
saywat?'s Avatar
Old Jul 28, 2015 | 06:30 AM
DRG35R's Avatar
20 Year Member
^ just by the look of that thing I have no idea how it would work with a conventional floor jack with a flat jacking surface. also it looks too wide to slip between lower rocker and pinch weld.
Old Jul 28, 2015 | 11:59 AM
Hatchman's Avatar
I just use a hockey puck. Works great, and have never had any damage to the body crease on any car. The puck is just soft enough to "fold in" and provide a nice, shallow v shaped slot to let the metal rest in, and it distributes the load equally over the entire surface to prevent in bends/damage.
Metal on rubber is much less likely to slip than metal on metal.
Cheap on Amazon.
Old Jul 28, 2015 | 01:55 PM
saywat?'s Avatar
my saddle was removable.im sure most are.. no worries it fits fine under the car
Old Jul 28, 2015 | 01:58 PM
Deepdiver's Avatar
I'm gonna check and see if mine is removable, if so, this is a great find.
Old Jul 28, 2015 | 02:03 PM
saywat?'s Avatar
^u would remove the cotter pin from under the saddle and the saddle comes off. thats how mine was. the adapter also come with a cylinder adapter if you have those full size floor jacks with the larger opening for the saddle
Old Jul 28, 2015 | 03:57 PM
LoSt180's Avatar
Cheap on Amazon.
I took it one step further and used a drill to cut a notch in my hockey puck. Slides right in, no issues. Cost was free since one of my friend's kid plays ice hockey.
Old Jul 28, 2015 | 04:34 PM
Urbanengineer's Avatar
Elastic limit of your pucks?
Old Jul 28, 2015 | 04:38 PM
saywat?'s Avatar
no one knows lol. i jus hope they cut the slit low enough that the weight of the car does not sit on the slit and sits on the sides of the puck instead.
Old Jul 31, 2015 | 10:23 AM
G35fromPA's Avatar
Good find, but I just place the jack and a small wooden block under the frame rail and have no issues.
AL8782
Oct 3, 2015 10:26 AM
Jeff T
Sep 30, 2015 02:00 PM
Hogbone
Sep 28, 2015 06:44 PM
