I'm running out of things to do to my G..
Old Mar 9, 2008 | 03:27 AM
  #31
absolutg's Avatar
workin...
nismo kit
Old Mar 9, 2008 | 01:26 PM
  #32
maxspeed96ct's Avatar
Id get that black molding going all around the bottom pianted body color
Old Mar 9, 2008 | 01:33 PM
  #33
06g35meister's Avatar
performance > looks
the G already looks good enough.
Old Mar 9, 2008 | 03:47 PM
  #34
ttrank's Avatar
Grocery getter
Here's my mod list to give you a few ideas:
Engine/Drivetrain:
Built motor going in in two weeks (Wiesco pistons, Tomei rods, JWT cams/springs)
Greddy TT
Greddy Front Mount Intercooler Kit
Greddy Profec B SPec II EBC
Custom Fresh Air Intakes Behind Grille with AEM Filters
Turbo XS UTEC
Turbo XS UTEC Tuner Lite
HKS SSQV BOV x3
Sun Hyper Ignition system
Sun Hyper Voltage system
AMS Radiator with high pressure cap
Coolingmist H2O/Methanol Injection
Stillen Grounding Kit
NGK Platinum 1 Step Colder Plugs
JDM Right Side Battery Cover
Unlimited Tuning Carbon Fiber Battery Covers
Greddy Oil Catch Can
Rogue Engineering Short Shifter
Jim Wolf Clutch
UR Flywheel
Nismo Oil Cap
VenAir Coolant Hose Kit
Upgraded power steering cooler
Exhaust:
Custom dual 3" exhaust with dual mufflers
Vibrant 3" downpipes
Vibrant open dump tubes routed back into the exhaust
Suspension:
Tein CS Coilovers
Tein EDFC
Stillen Sway Bars
Carbon Fiber/AL Front Strut Bar
Brakes:
Front: Rotora 380mm x 34mm 12 Piston (15")
Rear: Rotora 355mm x 32mm 4 Piston (14")
Rotora C2 pads
Motul Fluid
Exterior:
S2000 Upper Headlight Projector Retrofit
6000K Phillips Ultinon HID Bulbs
Acura TL Bi-Xenon Lower Headlight Projector Retrofit with ZKW lens swap
6000k GE HID Bulbs
*TL lower are high/low beam and S2000 upper are fogs*
Custom Hood Struts
UTR Grille
AAC CCFL Angel Eyes
Nismo Body Kit
iForged Aero 20x8.5F 20x10R
Kumho SPT 245/35/20F 275/30/20R
20% tint
2006 Taillights spray tinted and clear coated GT-R style
JDM Z Horns
Clear corners
3M Clear Bra on bumper cover, hood, A-pillars, side skirts, headlights, door edges, rear bumper, and lower half of front doors
Impul front bumper in work
Past wheels in some pics have been Zenetti Fives, Sevas S-55 and Volk GT-C, all 20".
Audio/Video:
Eclipse AVN 6600 Navigation Head Unit with Sirius and 80GB iPod.
Eclipse back up camera
Headrest Monitors
2nd Source DVD player in factory nav location (removed to install UTEC Tuner, EDFC and Greddy EBC)
JL Audio 1000/1 and 450/4 amps
Stinger 0ga wire and 15 farad capacitor
2 12” JL W6 Subs in fiberglass enclosures
Focal K2 Mids and highs (F&R)
Optima 34R Red Top Battery
Interior:
2005 G35 Coupe Seats
Forged performance shift ****
All LED Interior bulbs (doors, maps, dome and trunk)
KP White Shift Light
KP VDC Module
KP Mirror Tilt Module
KP Window Module
V1 with Mike's mount
AutoMeter Nexus Gauges and controller in custom pods (Wideband, Boost, EGT, Oil press, Oil temp, Fuel press)
Alarm:
Ungo 2-way remote start with window modules, interior temp sensor and trunk pop.
Old Mar 9, 2008 | 05:30 PM
  #35
BlueDevilBAMF's Avatar
Showoff...
Old Mar 10, 2008 | 01:04 PM
  #36
SoCalTed's Avatar
You've only just started... how can you say you are running out of things to do?
It doesn't sound like the mod bug bit deep enough, you haven't even ruined anything yet with any of your attempted mods!
-T
====my mods====
Engine, Drivetrain, and Exhaust
• TechnoSquare F-Spec ECU (soon to be replaced by Osiris)
• Zex Nitrous Wet Kit with rapid fire purge, remote opener, 860 Performance Pressure Regulated Bottle Heater, Blow Down Tube, DynoTune Digitial Nitrous Gauge, MSD Digital RPM Window Switch
• Polished Vortech SQ V2 Supercharger (installing now)
• RC 440 Injectors
• Spearco intercooler
• Walbro 255/lph high flow fuel pump
• 1 step colder plugs
• Crawford v5 Performance Plenum,
• 350Z air duct with custom thermo-wrap,
• SAMCO Coolant Hoses,
• Earl’s ProLite 350 Braided Hose,
• GroundingGear™ 10-wire kit
• Stillen Hi-Flow Airbox
• DC Sports Headers
• Unorthodox Racing Pulley (crank only – in blue)
• Stillen Cat-back True Dual Exhaust
• Stillen Oil Cooler
• Stillen Engine Brace/Damper
• Custom High Flow Cats
• DMH Performance Electric Cutouts with custom Fabritech race readies
• Custom Aluminum Racing Radiator by Griffin
• Custom mechanical to electric crank fan conversion
• 170 Degree Thermostat
Wheels, Tires & Suspension
• Enkei RP03 19x8.5 & 19x9.5 Lightweight 1-pc forged wheels
• Dunlop Direzza DZ101 Tires: Staggered 245/35/19 & 275/30/19
(Fender line is cut, not rolled)
• Tein Flex Coilovers
• SPC Performance Rear Camber Kit
• Ichiba Front Camber Kit
• Stillen Sway Bars
Exterior:
• Full NISMO kit
• Custom T-Rex Billet Grilles
• Aerotect clear bra (full hood & mudguards, front bumper & fenders, and side mirrors)
• Tinted Windows with SolarGard Quantum (19% r, 28% fr, & 50% windshield)
• Blue Batmobile Rear Tailight Overlays
• JDM Clear Corners, keeping the amber bulbs
• Upgraded OEM parking lights (city lights) to PIAA High Intensity Super LEDs (#19263).
• Upgraded OEM Fogs to Euro Type-R HID 4500K Super Whites (#TR-504).
• Underbody LEDs
Interior:
• Innovate Motorsports LM1 A/F Meter and RPM Converter
• Custom carbon fiber switching panel (center cup holder)
• B-Quiet VComp and BComp sound dampening (trunk and rear seats)
• Hardwired Valentine V1 Radar/Laser detector with Auto-POP and concealed remote display
• BCT7 & BCT10 BearTrackers
• Hardwired BCT7 Beartracker in armrest.
• Portable BCT10 is mounted under dash and is used for city driving (no aircraft monitoring)
Audio is run through a cassette adapter into the stereo. Scanner is selected from stereo wheel's audio controls (mode=tape) Antenna is mounted in the rear headliner.
• DVD/MP3/CD-R/VCD Player Custom installed in Rear Armrest
• Varad Amber LED Mood Lights
• Playstation 2 wired through the NAV/Tuner
• AV Electronics NAV/Tuner
Old Mar 10, 2008 | 03:00 PM
  #37
68_GT's Avatar
IMO do something with the black around the bottom before anything else. Nismo kit would be nice but fairly expensive for all the parts.
next I'd lower it with some revised Z springs and maybe get lower profile tires next time ?? Not sure what size tires you have on the 19's now but they look tall on the sides.
Old Mar 10, 2008 | 03:03 PM
  #38
SDGeneralCounsel's Avatar
Originally Posted by Granto86
I just put couple 19s on my car and am pretty happy with them and dont think i'm gonna lower it now since i have to deal with alot of speed bumps and stuff.. Any ideas though on what else I should do? check my sig for what I have so far.
I think you mean that you have run out of inexpensive mods to do. You still have a grip of work to do on this car
Old Mar 10, 2008 | 06:04 PM
  #39
Klubbheads's Avatar
coupe seats, OEM brembos, Isiris Tune.... just to name few.
Old Mar 18, 2008 | 02:48 AM
  #40
Granto86's Avatar
Originally Posted by 06g35meister
wait who? my pal from HS cant remember his name, haha, has a golf and races it... had a white miata before that, where did you go to HS?
Haha, thats crazy, we're both talking about Thomas, this is Grant Williams, I went to East, who is this?
Old Mar 18, 2008 | 03:04 AM
  #41
Granto86's Avatar
Originally Posted by MIA BlazinVQ
yo Grant how do you like the 19s so far man? they're looking good on the ride!
Yea man, I really like them, thanks alot! Im thinking about getting some 350z h-techs to complement them, so we'll see how that goes soon
Old Mar 18, 2008 | 03:06 AM
  #42
Granto86's Avatar
Originally Posted by BlueDevilBAMF
I've got an '05 coupe midpipe...
And I grew up in OP! 2 of my friends at KU Med live in Westwood not too far from PV.
Thats pretty cool, I have some friends who go there too, and i think i'll pass on the coupe midpipes, from what i've read theres some droning that goes along with them, Im gonna hold out for the rare 05 sedan midpipe to come round my way sometime..
Old Mar 18, 2008 | 08:02 AM
  #43
psedog's Avatar
Back in SD**
Paint your lower sills, get a lip, and add this mod https://g35driver.com/forums/interior-exterior/189994-make-custom-carbon-fiber-rubber-splitter-your-aftermarket-bumpers.html
Old Mar 19, 2008 | 02:10 AM
  #44
kiko's G's Avatar
Get a new car...
Old Nov 9, 2009 | 07:03 PM
  #45
tdruk's Avatar
Originally Posted by kiko's g
get a new car...
hate!!!
