Need a little help W/suspension guys
Originally Posted by Hotnikks
How's your car ride on the 225's? That's what I wanted to get but got talked into keeping the oem sizes.
^^yeah that's exactly right just sometimes. I'll be sure to check those out. What do they need a little retightening? Is there any torque specs on those or no?
I'd have to check the manual about torque specs. Normally I'd just say tighten them as snug as they were when you took them off. As for the sound, you probably have to replace them. Just replace them when you get new sways, unless you already have them.
If anyone thinks their sedan is just below stock ride height, someone may have installed eibach pro kits they are only a very moderate drop, about an inch. I bought my G and I was never sure. When I put my H&R/Koni setup on i found out I had the pro kits.
bTanz
Oct 15, 2015 02:31 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
