most aggressive sedan fitment?
Apr 6, 2008 | 12:14 PM
  #31
Quote: Damn, that's either a photoshop, or you got a lift kit put on that front end.
Nope, it's called factory suspension. lol
Reply 0
Apr 6, 2008 | 09:50 PM
  #32
Quote: I need more information, is the car lowered at all? If it is, how much? What are your current camber settings?
If the car isnt lowered, the wheels are going to stick out about a half inch in the rear. If you lower the car, you can fit that wheel with a 275/30 tire or you can stretch it a little and go with a 255/35. I wouldnt go with that low of an offset if you aren't planning on lowering the car. Look for something above 40.
The lower the offset, the more the wheel will stick out. Plain and simple.
-GP-
Currently its not lowered, and thanks you pretty much cleared up any questions i have/had. thanks
Reply 0
Apr 7, 2008 | 11:08 PM
  #33
How's this for a possible setup?
Lowered 1.75"front and 1.50"rear, no camber kits
18x8.5 +38 on 245/40/18 front
18x9.5 +38 on 275/35/18 rear
But, they do make the wheel in a +30 offset as well, just don't know if that will fit in there.
Reply 0
Apr 8, 2008 | 12:30 AM
  #34
Get +48 on the rear if you can get it. Then it will fit without rolling your fenders.
Reply 0
Apr 8, 2008 | 05:26 AM
  #35
Quote: 19x9/10 +25 235/35F 255/35R with the car dropped atleast 2 inches and -2.0 camber all around.
-GP-
Your awesome, thanks!
Reply 0
Apr 9, 2008 | 12:19 AM
  #36
Ok guys, +15mm spacer is on. It fits. Here are some shots when I get her clean I will take more.
Reply 0
Apr 9, 2008 | 07:06 AM
  #37
Quote: Ok guys, +15mm spacer is on. It fits. Here are some shots when I get her clean I will take more.
Does it rub? Is there any camber adjustment? which spacer did you use?
i love it!
Reply 0
Apr 9, 2008 | 09:38 AM
  #38
No rubbing, but I havent had anyone in my car. I didnt rub when I had the 10mm. I dont have a camber kit, but if is comes close to rubbing I might have to dial in some neg. I used a project kics spacer. I am also getting one for the front. +25 all around.
I like to thank Gdup and Redlude for helping me out on the spacers. Next wheels and when I get them are going to be aggressive.
Reply 0
Apr 9, 2008 | 10:38 AM
  #39
Here is my setup. Front 19" x 8.5" +38 with a 235/35/19 and the rear 19" x 9.5" +43 with 265/30/19. I think this is the correct offset that I am running. I bought them like three years ago and memory is not that great. I am going to try a 275/35 rear in the next few weeks and see how that looks.
Reply 0
Apr 9, 2008 | 05:20 PM
  #40
Quote: No rubbing, but I havent had anyone in my car. I didnt rub when I had the 10mm. I dont have a camber kit, but if is comes close to rubbing I might have to dial in some neg. I used a project kics spacer. I am also getting one for the front. +25 all around.
tight.. wanna sell me that 10mm spacer?
what are you lowered on?
Reply 0
Apr 9, 2008 | 05:48 PM
  #41
I am lowered on 350z s-techs front and 350z h-techs in the rear. As for the 10mm I might keep it for now, but someone already has dibs on them.
Reply 0
Apr 20, 2008 | 06:11 AM
  #42
Sorry to hijack this thread but what the heck..
Am looking at a set of wheels for my sedan which will be lowered on Z springs.
18x8 +37, 18x9 +39.
Can one of you wheel offset gurus please let me know if I will need any fender rolling? The fronts I'm pretty sure will fit no problem, its the rears I'm a bit iffy.
Thx!
Reply 0
Apr 20, 2008 | 08:36 AM
  #43
you should be fine in the rear.
Reply 0
Apr 20, 2008 | 09:30 AM
  #44
Quote: Here is a pic of my 275/35/19 on a 9.5 rim +48 offset. I have a camber kit also. I think the fit is pretty perfect.
I think these sit the best out of all those that have been shown. How much of a lip do you have in the rear?
Reply 0
