Dealer not following FSM proceedures
Apr 8, 2008 | 06:58 PM
Just thought I would bring something to everyone's attention. I was trying to buy some parts recently from the dealer and they told me that when servicing the coolant, transmission, and differential, they don't replace the necessary o-rings/washers as stated in the FSM. It explicitly says "do not re-use the old part, use a NEW part." So for those of you that are paying for "quality" service, take note..
I'll admit I've done the services without replacing those things, but at least if you're already paying someone good money to do it, they should do it by the book.
here are the photos of the parts:
Radiator drain plug and bleeder valve o-rings
Washer for MANUAL transmission/differential drain/fill
Reply 0
Apr 8, 2008 | 07:15 PM
Quote: Just thought I would bring something to everyone's attention. I was trying to buy some parts recently from the dealer and they told me that when servicing the coolant, transmission, and differential, they don't replace the necessary o-rings/washers as stated in the FSM. It explicitly says "do not re-use the old part, use a NEW part." So for those of you that are paying for "quality" service, take note..
Attachment 86768
Washer for transmission/differential drain/fill
Attachment 86769
are you saying that all dealers dont follow the FSM or just your local dealer?
im lost here..
Reply 0
Apr 8, 2008 | 07:16 PM
Quote: are you saying that all dealers dont follow the FSM or just your local dealer?
im lost here..
I'm not sure.. could you call your local dealer and find out if they replace these when doing MT and/or differential service?
Reply 0
Apr 8, 2008 | 07:17 PM
My guess is that if one were to go to any shop to have these services done that they would make sure that these parts would be replaced as per FSM.
Reply 0
Apr 8, 2008 | 07:35 PM
Quote: My guess is that if one were to go to any shop to have these services done that they would make sure that these parts would be replaced as per FSM.
that is wishful thinkin my friend.......stealerships scrimp on it...especially something you'll never be able to verify. best solution = DIY!
Reply 0
Apr 8, 2008 | 07:36 PM
Quote: that is wishful thinkin my friend.......stealerships scrimp on it...especially something you'll never be able to verify. best solution = DIY!
hence why I post DIY vids
Reply 0
