do our seats fold down.
Old Apr 9, 2008 | 05:55 PM
Jeff92se's Avatar
Red Card Crew
Do those ***** come off? What's those gold/black rods next to the height adjusters?
Old Apr 9, 2008 | 05:59 PM
Klubbheads's Avatar
Originally Posted by Jeff92se
Do those ***** come off? What are those gold/black rods next to the height adjusters?
Maybe this pic will help u.
Old Apr 9, 2008 | 06:11 PM
Jeff92se's Avatar
Red Card Crew
I guess it helps. Those are adjusters for the rear? Bendable? Looks like you might need to fab another set that's only about 10% the length so you can have them in the car all the time.
Old Apr 9, 2008 | 06:34 PM
Klubbheads's Avatar
thanks jeff, so i guess they do come with the adjusters.
Old Apr 9, 2008 | 06:37 PM
dofu's Avatar
20 Year Member
You can always drill some holes for the adjusters...
Old Apr 9, 2008 | 07:40 PM
ILLicit's Avatar
There are holes in the back, once you remove the rear deck, there are 2 rubber covers covering the shock mount, remove it, and you got access to your rear shocks. We discovered this when we stripped the entire interior in DieselX's car to dyanamatt it. I'll see if I have any pictures of it.
Old Apr 9, 2008 | 07:42 PM
Klubbheads's Avatar
^thanks, which is more time consuming? Doing that or taking the shock apart??
Old Apr 9, 2008 | 07:44 PM
ILLicit's Avatar
You'll need to remove back cushion to get to them. Def more time consuming to remove the shocks.
Old Apr 9, 2008 | 07:52 PM
Klubbheads's Avatar
^that helps a lot, Thank you!
Old Apr 9, 2008 | 08:02 PM
Philly_G35's Avatar
I have heard if you have rear reclining seats you can access the top of the shock to adjust them.
Edit: Searched and found this. https://g35driver.com/forums/showpos...64&postcount=4
Old Apr 9, 2008 | 08:07 PM
G35Papa's Avatar
Yes, if you have the premium package (reclining rear seats) you can get to them easily..nothing needs to be removed. Just a cover that is velcro'ed needs to pulled aside and you can get to them.
I can snap a pic if it helps
Old Apr 9, 2008 | 08:19 PM
Gilley's Avatar
I have the BC Racing coilovers on my coupe. The extenders attach to the **** at the top of the shock with an allen wrench. You can shorten the cable if you need to by cutting the outside sheath and the inner cable.
Old Apr 10, 2008 | 12:27 PM
Klubbheads's Avatar
I love this forum!
G35papa snap a pic if u get a chance.
Thanks a lot everyone.
Old Apr 10, 2008 | 01:02 PM
Boston's Avatar
I dunno about the BC units. Have a pic of the top of one rear? Extenders are just a cable thingie that attaches to the top of the rear adjuster and allows it to poke though the rear shelf. You might be able to snake it though to the child seat tie downs or poke a hole though the rear shelf?
That's the set up I had with my D-Specs on my coupe. I drilled a hole through the top mount and snaked my dampening extension up into the rear deck under the child seat tie down. I know Tokico offers the extensions but not sure about BC.
Old Apr 10, 2008 | 03:00 PM
  #30
ttrank's Avatar
Grocery getter
This is why I love my EDFC.
