New Setup
Old Apr 12, 2008 | 01:32 PM
jack_burton's Avatar
New Setup
Hey guys just picked up these. I wanted to run Sedan H Techs but I'm a total nut and want every last detail. Is the dampening on these shocks good enough to support the h techs? Also I'm running stock rims with 235/50/17 and do not want them to rub anywhere. Am i good or no?
Old Apr 12, 2008 | 03:07 PM
perry05G35's Avatar
Are those Tokico D specs? If so you'll be good to go with Sedan H techs or any other spring for that matter.
Old Apr 12, 2008 | 03:18 PM
no they are not the dspec, just the regular HP series blue shock
Old Apr 12, 2008 | 07:44 PM
02themax's Avatar
I have Htechs on stock shocks with Coupe 19's. i have absolutely NO rubbing issues at all. You'll be fine with that setup, I will say that the rear htech shocks are softer than stock. Get sways next you'll love em.
Old Apr 13, 2008 | 04:15 AM
perry05G35's Avatar
Okay yes you'll be fine H techs don't give you that much of a drop though so if you'll looking for a slight drop you'll be good to go with the H techs.
Old Apr 13, 2008 | 04:34 AM
O HELLA JDM's Avatar
are h-techs for the sedan feel like stock and with s-techs need camber right??
Old Apr 13, 2008 | 01:37 PM
perry05G35's Avatar
^ most likely you'll need a camber kit to get your camber back into sedan spec but you could have them put your camber at coupe spec but a lot of shops won't do it unless you specifically ask them too and they will most likely give you the cons of going that route which is faster tread wear. See how close they can get you and ask yourself if it's worth it to go with a $140.00 camber kit.
Old Apr 15, 2008 | 04:59 AM
deuceduzit's Avatar
so....If I get sedan s-techs....Do you recommend the front camber kit? Or just the rears??? I'm just wondering how bad the fronts would be....
Old Apr 15, 2008 | 05:15 AM
perry05G35's Avatar
Get the springs installed then ask the shop that does your alignment which kit you'll need and go from there the front is a lot more expensive then the rear.
Marlin84
Apr 1, 2020 12:52 PM
DRG35R
Jan 31, 2016 07:14 AM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
AL8782
Oct 3, 2015 10:26 AM
JustinMKN1
Sep 18, 2015 03:40 PM
