quick question... headed to autozone
Old Apr 13, 2008 | 10:13 AM
g35tl600rr's Avatar
what is the screw size on the splash guard cover under the car? several came off last night and now its draging.(the ones you remove to change the oil) thanx
Old Apr 13, 2008 | 10:17 AM
HUMBOLDT_G's Avatar
Maybe you should pull out one that is still in there to find out. If the clips are stripped you may need to go to a bigger size.
Old Apr 13, 2008 | 10:19 AM
citymunky's Avatar
Go to NAPA, with one of the bolts, and get you some new ones
Old Apr 14, 2008 | 04:49 PM
JMAN44544's Avatar
I know they are 10 mm heads, and when you are lying on a creeper loosening them, it feels like there are 400 of them.
Old Apr 14, 2008 | 05:44 PM
Idyfohu's Avatar
They are 10mm.
I was thinking it was going to be worse, but it wasn't bad at all. Just loosen them with a 10mm socket and then use a powerdrill with a philips extension to extract them. Cake.
Old Apr 14, 2008 | 08:17 PM
Carlito's Avatar
Originally Posted by Idyfohu
They are 10mm.
10mm head, but likely a M6 thread. Was trying to find the part but somehow it's not coming up.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
BradMD_96
Oct 6, 2015 09:31 AM
Jcruzg35
Sep 26, 2015 04:47 PM
